Ford vs The Competition Technical discussion and comparison ONLY. Trolls will not be tolerated.
OHC vs. OHV
Old Apr 20, 2005 | 06:24 PM
BVFD1983's Avatar
BVFD1983
OHC vs. OHV
First off, everyone means that OHV refers to a pushrod engine.
All modern engines that I know of have overhead valves. That said, isn't it a bit redundant to say OHV? It's like "duh."
Old Apr 20, 2005 | 06:29 PM
tmyers's Avatar
tmyers
Then please tell us how to differentiate between the 2.
Old Apr 20, 2005 | 07:58 PM
BVFD1983's Avatar
BVFD1983
Pushrod and OHC.
Old Apr 21, 2005 | 12:37 AM
Al Bundy's Avatar
Al Bundy
I believe more modern engines are Over Head Cam nowadays. It produces more power than OHV.
Old Apr 21, 2005 | 01:48 AM
seftonm's Avatar
seftonm
Al, I think what BVFD1983 is saying is that every engine today has the valves overhead. Both OHC and pushrod engines put the valves at the top of the combustion chamber so technically, "OHV" is meaningless in differentiating between the two. Most of us have grown to accept what OHV means though.
Old Apr 21, 2005 | 11:02 AM
jimandmandy's Avatar
jimandmandy
It is not totally meaninless because many small equipment engines are still flathead. While OHC may be good for high rpms, pushrod, or OHV, engines produce plenty of power. The new Corvette Z06 will get 500hp from a 7.0L non-boosted pushrod engine. Dodge "Hemi" is another example. The Navistar diesel in the SuperDuties is no slouch either.
Jim
Old Apr 21, 2005 | 02:59 PM
BVFD1983's Avatar
BVFD1983
Why oh why can't Ford do this?
Old Apr 21, 2005 | 03:13 PM
ARMORER's Avatar
ARMORER
Why would they have to when the get 500+ horsepower out of 5.4 liters in the GT?? The correct question may be "Why doesen't Chevy use OHC?"
Old Apr 21, 2005 | 04:07 PM
BVFD1983's Avatar
BVFD1983
I was referring to the "non-boosted" in the post.
Why can't Ford make a naturally aspirated engine with 400 hp and 400 ft. lbs?
Then the buyer can add a blower or turbo like Lingenfelter does. Those cars are BAD!
Old Apr 21, 2005 | 04:46 PM
tmyers's Avatar
tmyers
That is a mis-conception, they just don't add a blower or turbo. They rebuild the entire engine. Stock compression of the LS2 is 11 to 1. You can't add a blower or turbo with that type of compression unless you are going to run race fuel. So for about 7k you get 100 more HP and only 40lbs more torque.
Old Apr 21, 2005 | 10:09 PM
BVFD1983's Avatar
BVFD1983
I know a guy who has a 2002 Z28... Blown with no internal mods. He has headers and all that good stuff, says it makes 500 at the wheels.
Old Apr 22, 2005 | 01:10 AM
NickFordMan's Avatar
NickFordMan
People say a lot of things. I think this whole thread is redundant. Why argue against using OHV?
Old Apr 22, 2005 | 05:46 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Same as a the go pedal thread...just keep comparing the two and we are OK
Old Apr 22, 2005 | 11:11 AM
BVFD1983's Avatar
BVFD1983
Because it is stupid to call a specific group of engines something that all automobile engines (aside from the RX8) are.
DOHC = OHV
Why can't the common words for them be DOHC and pushrod?
Old Apr 22, 2005 | 11:32 AM
emxmagnum's Avatar
emxmagnum
I think its a simple matter of history. First, engines were "flat". Then the wonderful technology of over head valves came along. So, to differentiate the two, they called em OHV. Then, they decide to put the cams up top as well. So, to differentiate, they called it OHC. If there were only two types of engines (OHV and OHC) then OHV would be redundant. Since there are not, OHV is needed.
So, they said OHV to distinguish between it and flat head engines. Then OHC to distinguish from the other two.
