Ford vs The Competition Technical discussion and comparison ONLY. Trolls will not be tolerated.
OHC vs. OHV
Old Apr 22, 2005 | 01:22 PM
BrentKasson's Avatar
BrentKasson
You can't differentiate the two by using dohc and ohv. What about all the Single Overhead Cam engine configurations?
Old Apr 22, 2005 | 05:14 PM
NickFordMan's Avatar
NickFordMan
SOHC ever heard of it?
Old Apr 22, 2005 | 07:40 PM
Ben99GT's Avatar
Ben99GT
Originally Posted by BVFD1983
I was referring to the "non-boosted" in the post.
Why can't Ford make a naturally aspirated engine with 400 hp and 400 ft. lbs?
Then the buyer can add a blower or turbo like Lingenfelter does. Those cars are BAD!
Ford can and does. Look at the 5.0L cammer engine.
Like any high performance n/a engine worth it's weight, you probably wouldn't want o just slap and blower or turbo on it because it's high compression. Unless you like running 5 pounds (or less) of boost.
If I had forced induction I would want to crank up the boost.
Old Apr 22, 2005 | 11:15 PM
Al Bundy's Avatar
Al Bundy
Originally Posted by jimandmandy
It is not totally meaninless because many small equipment engines are still flathead. While OHC may be good for high rpms, pushrod, or OHV, engines produce plenty of power. The new Corvette Z06 will get 500hp from a 7.0L non-boosted pushrod engine. Dodge "Hemi" is another example. The Navistar diesel in the SuperDuties is no slouch either.
Jim
Correct me if I'm wrong but isn't the navistar diesel a 32 valve dohc configuration? I believe thats what it states in my owners manual.
Old Apr 23, 2005 | 01:42 AM
AG4.0's Avatar
AG4.0
32v's but not OHC I believe.
My opinion, the English language is full of words and phrases that don't always get used correctly, but everyone knows what is meant. If I need a tissue, and ask for a Kleenex, a Puffs will work just fine. My point is, that if we all understand what's being said, who really cares. Most of us here understand that OHV is pushrod, and OHC could mean SOHC or DOHC, and those who don't eventually figure it out. Not a big deal.
Old Apr 23, 2005 | 02:06 AM
77_F150_4x4's Avatar
77_F150_4x4
I will agree with the gm talk about ohv engines the camaros and firebirds are fast they don't even have a dual exhaust set up like a stang due to the torque arm they use , but still one of my friends has a WS6 thats running high 11s all stock internals naturally asperated and on a 3.23 gear out back. for 01 vs 01 the ta is making more torque 23 more at 2000 less rpm and 10 less horses at 800 less rpms.
Old Apr 23, 2005 | 08:39 AM
2000BLK54's Avatar
2000BLK54
As for the whole GM:Pushrods::Ford:OHC argument...waste of time. It's a packaging and cost issue...not which design makes better power. Ford can and has made excellent pushrod mills as well as GM has some worldclass OHC engines.
For the actual topic at hand.
There are as many pros as there are cons with both. Neither is inherantly better than the other.
Old Apr 23, 2005 | 10:20 PM
NickFordMan
Why? Why is this thread still going?
Old Apr 24, 2005 | 06:02 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Because it is following the Guidelines and members are participating
Old Apr 24, 2005 | 08:09 AM
4wd's Avatar
4wd
the flat head is a push rod motor too (IE. Briggs and Stratton), so you maybe you can just use the differientiation of a pushrod motor and an ohc motor.
I thought they went to OHV engines for efficiency. The old flat head V-8 100 hp Ford had
poor fuel mileage, but was bullett proof.
Manitoulin's Avatar
Manitoulin
OHC are nice and easy to time
Old Apr 24, 2005 | 12:45 PM
NickFordMan
Tim, that wasnt directed towards u, i was wandering why people are actually still participating
Old Apr 24, 2005 | 12:58 PM
  #28
IB Tim's Avatar
IB Tim
I know...I let this one go and the go pedal one....because once in awhile you got to have some fun...this forum is sooo serious and dark at times.
It is healthy to laugh at ourselves sometimes
Old Apr 24, 2005 | 01:14 PM
  #29
NickFordMan
I never looked at it from that perspective. Good to have you around Tim.
Old Apr 26, 2005 | 07:15 PM
  #30
rebturtle's Avatar
rebturtle
I'm glad that at least some are paying attention and are laughing at this. I agree with BVFD1983's original post. A '56 Chevy, '73 Pinto, '93 Mustang, and a Honda lawnmower all have overhead valves.
Perhaps the only manufacturer to continue make a "flathead" or non-overhead valve motor in the last 50 years is Briggs & Stratton. The OHV nomenclature has been driving me nuts ever since I bought my newest Ranger with the 4.0L.
