1978 - 1996 Big Bronco
3-wire or 5-wire power door locks?
Old Apr 20, 2005 | 10:05 AM
BootHill's Avatar
BootHill
I have a '96 Bronco I'm installing an alarm on and need to know if the power door lock system is a 3-wire positive, 3-wire negative or 5-wire system - would like to know before I tear into it. Anyone know? Thanks in advance
Old Apr 20, 2005 | 11:50 AM
f1001978's Avatar
f1001978
My 90 bronco has 5-wire, so I needed 2 5-pole relays and a mess of wires for my alarm. There are some good sites on the internet that have alarm wiring diagrams for all kinds of cars.
Old Apr 20, 2005 | 07:29 PM
buckeyebronco's Avatar
buckeyebronco
My 90 was 5 wire also but my alarm was made to hook up to all kinds of systems and I didn't need any auxillary wiring. Check out a Haynes manual for wiring diagrams.
Old Apr 20, 2005 | 08:58 PM
BootHill's Avatar
BootHill
I found some wiring color guides, thanks. Any online sites with good install guides that you recommend?
Old Apr 21, 2005 | 04:39 PM
wjawill's Avatar
wjawill
I'm gettin ready to do the same thing to my 94. Some good sites are www.th12volt.com and www.bulldogsecurity.com. They have wiring diagrams and everything. If you have the factory keyless you are gonna need some relays and a whole bunch of wiring. Autozone has the relays in the auxilary lighting section for like 4 bucks. Btw you can get a window module and another relay and wire your tailgate window too.
Old Apr 21, 2005 | 04:53 PM
tHeCoS's Avatar
tHeCoS
I got my truck with an alarm system and it never worked. I've been tempted to remove all the alarm system wiring. Anyone been able to successfully remove all the alarm system wiring?
Old Apr 22, 2005 | 10:11 AM
BillyBob69's Avatar
BillyBob69
www.12volt.com is an EXCELLENT site. I used them for wiring diagrams for my keyless entry and remote start.
And yes it is a 5 wire. Requires 2 relays for keyless entry.
samper
Jul 8, 2016 06:27 PM
albinorhino
May 23, 2015 04:25 PM
WVmountainman07
Electrical Systems/Wiring
Jan 20, 2015 06:43 AM
tazaxx
Oct 11, 2014 09:33 PM
ryankerr
Mar 5, 2014 10:06 AM
