Offroad & 4x4
Divorced t-case brace
Old Apr 19, 2005 | 07:25 PM
Thomsen's Avatar
Thomsen
I was thinking of putting a brace that would keep the divorced transfer case on my 70 F-250 from flexing. When in 4 low i can see that the t-case moves back and forth. I have replaced the bushings but it still does it. I was thinking of building a crossmember from flat metal and then welding a bar from the crossmember to one of the t-case plates so that it can be removed also. What do you guys think.
Old Apr 19, 2005 | 07:40 PM
proeliator's Avatar
proeliator
Its always a good idea. I did it for mine:
Old Apr 19, 2005 | 07:50 PM
Thomsen's Avatar
Thomsen
Thanks for the pic pro that is exactly what i was thinking. Btw how do you like the 5.13 gears. I was thinking about those gears when i get my 60 front. Our tires are close in height and was wondering how you like the gearing. I do have the dana 24 t-case with the, i think, 1.86 low range. While yours is the 205 with a 1.96 low range. So it shouldnt be too much different. Oh and what is the true height on 44'' boggers. My 42's have a true height of 41 3/4''. Thanks
Old Apr 19, 2005 | 07:55 PM
proeliator's Avatar
proeliator
I like the 5.13s. 5.38s probably would have been optimum but they aren't available for a d70. 44" Boggers at low end street pressure measure out closer to 43's...part of that is that they have a flat tread block where the swampers are crowned. The Dana 24 is a great xcase, every bit as strong as the np205.
Old Apr 19, 2005 | 08:21 PM
Thomsen's Avatar
Thomsen
Yeah i haven't had a single prob with my t-case in terms of strength. As of right now i dont even use my high range because of the 4'10s unless the mud isn't real deep. I'm hoping to be able to use the high range for mud bogging and use my low range for some trails and crawling with the 5.13's.
Old Apr 20, 2005 | 08:31 AM
brokebronco's Avatar
brokebronco
Pro thinks up the coolest stuff. Like the cutouts.
Chris
Old Apr 20, 2005 | 11:10 AM
ivanribic's Avatar
ivanribic
Chris
And like reving his engine when someone is under his truck cleaning it so his exhaust deafens them to deaf. Good times . . . good times . . .
Old Apr 20, 2005 | 07:12 PM
proeliator's Avatar
proeliator
Now if only I could make a Mr. Fusion!
Ivan should just be happy I'd capped the cutouts before I fired her up with him down there. Its cuz I'm so damned sensitive to the needs of others, thats why
One of the reasons my stuff holds together so well (more or less) is that I've braced the hell out of everything...when running a divorced unit an extra brace like this is always smart money.
Old Apr 20, 2005 | 07:33 PM
monsterbaby's Avatar
monsterbaby
Pro I am just curious with all the extra bracing and building you have done to that truck have you ever weighed it I would be curious what that monster weighs.
Old Apr 20, 2005 | 07:36 PM
proeliator's Avatar
proeliator
It weighs close to an even 6k. Not bad, all things considered.
AK FORD GUY
24
Aug 3, 2021 08:57 PM
mister 460
Aug 4, 2003 08:42 PM
WC76TX
May 10, 2002 02:10 AM
larbuck
Nov 29, 2001 01:08 PM
