1978 - 1996 Big Bronco
A/C problems
Old Apr 27, 2005 | 10:19 AM
kameronth's Avatar
kameronth
I am right up on refrigerant. I think that the switch was just bad. I will replace it tonight and see. Thanks for the help.
Old Apr 27, 2005 | 09:33 PM
Grogtronics's Avatar
Grogtronics
How did the switch replacement go?
Old Apr 28, 2005 | 12:42 AM
kameronth's Avatar
kameronth
Well, I picked one up from the zone and it did not make a proper seal. So I returned it and got one from Checkers that came with a o-ring. It worked great, I had to add some more freon because I lost a bunch when the schrader valve gave way. Now my a/c works good and cold! Thanks for the help!
Old Apr 28, 2005 | 03:00 AM
muckypaws's Avatar
muckypaws
great news!
Old Apr 28, 2005 | 01:09 PM
Fordbyford's Avatar
Fordbyford
Im having problems with my A/C aswell I'll turn it on and hot air will come out instead of cool hopefully just need charging anyone else have this problem if so what did you to fix it????
Old Apr 28, 2005 | 02:04 PM
Pookie's Dad's Avatar
Pookie's Dad
Read the the Post that "MuckyPaws" wrote. I tried what he suggested and had the same results as "Kameronth". I went today and bought a new switch and a couple of cans of freon just incase mine is a little low too. Kameronth replaced his switch and that fixed his problem, hoipefully that will fix mine too. I'll let you know.
Old Apr 28, 2005 | 07:00 PM
ALSAIR's Avatar
ALSAIR
There is a white hose on your truck that controls the vacuum. It is located on the fire wall above the blower. Check it for leaks, it cracks, and could be the cause of your specific problem.
Al
Old Apr 28, 2005 | 07:07 PM
Pookie's Dad
IT WORKS !!!!! I replaced the Low Pressure switch and the compressor cuts on and off by itself, and its blowing about 50 degrees out of the vents. Thank You for you post "MuckyPaws" & "Kameronth". I owe you both a lunch or dinner if your ever in San Antonio.
Old Apr 28, 2005 | 07:49 PM
kameronth's Avatar
kameronth
Glad to hear you got it figured out! You don't owe me anything, that is what this site is for, to help each other out.
bodabdan
Jun 12, 2012 09:55 PM
riverratmike
Oct 13, 2010 09:03 AM
racerx6466
1997 - 2003 F150
Jul 29, 2009 08:09 PM
desertranger
Escape & Escape Hybrid
Jul 15, 2009 06:31 PM
geneb11
Jul 27, 2003 08:32 PM
