Dealer said it's just the nature of the beast, no need to worry, It was a question I figured I would ask since It was going there any way. The rest of the story on the 4 wheel drive is in the other thread though, so if your interested go there, otherwise thanks for the replies, I was curious if this is a commen symtom, seems to be. like I said earlier my 85' 302 has a very rough idle and has had it from day one so I figured it wasn't anything major, as stated before just the nature of the beast.
Mine does it as well. You can pull up to a stop light and feel it sometimes. My 4.6 in the Mustang does it as well. I don't think it is anything out of the ordinary.
there IS a counter balancer in the drivers side head, my guess would be that the engine isn't, nor can't be perfectly balanced. I have a little puke*sputter*wobble once in a while at start up but otherwise it idles fine. It isn't an engine that I have to look at the tach to see if it's running though (not that I have a tach). But she is mighty smooth and friendly, more so than any other engine I've ever owned.
Like I said before, I knda figured this was normal and it is just a smooth as silk except when I'm stopped and its just idling. I then get a little blip every now and again. I figured I might as well ask since it was going in any way.
In a V8, all pistons are moving in directions where they cancel each other out. The V10, being a 90 degree block, can't do that, so the balancing shaft is a must. If it was a 72 degree block, we wouldn't need balance shafts.
Actually, my '01 V10 seems better balanced than my 4.6l's ... The rear-view mirror is rock steady no matter what in the SD ... the 4.6l's do vibrate a little bit around 2000 and 4000 rpm... The V10 is smooth as glass...
This is one of those things that I never notice, until someone brings it up. But yesterday I'm in traffic, and everytime I stop, I listened and felt for any vibration or shake, honestly, I felt none. I knew it was running, but I had no miss, no nothing, just a gentle, almost lullaby-ish rhythm, it was lovely. I almost nodded off just experiencing the bliss of a running 6.8 V-10, it was a magical moment to be sure. And I get them whenever I want, I just have to come to a stop, and let her idle, mmmmmm, nighty-night,,,,zzzzzzzzzzzzz Peace bro,,,,,KS
