HELP Clutch problems
Old Apr 18, 2005 | 03:06 PM
DT 466Man's Avatar
DT 466Man
On my way to school i felt my clutch wasn't releasing all the way. So i checked the fluid Full. The firewall doesn't flex and the hyd cylinder on the bellhousing moves about an inch.
I'm going to try to bleed it and see if that helps.
Any ideas?
Also why does the brass fitting i have for my mechanical guage leak when it's tight? I have a 2" nipple into a tee and it's leaking.
Old Apr 18, 2005 | 05:04 PM
DT 466Man's Avatar
DT 466Man
well i adjusted it at the pedal and it worked 100 percent. But it is starting to get mushy again.
You think it is my Clutch master cylinder?
Old Apr 19, 2005 | 05:00 AM
5_labsownus's Avatar
5_labsownus
Time for a new clutch most likely!
Old Apr 19, 2005 | 11:20 AM
77300i6's Avatar
77300i6
The brass fitting may be leaking because it is too tight. Sometimes that will happen. Also, if there is any heat build-up, brass has a different expands more than metal.
Old Apr 19, 2005 | 02:50 PM
DT 466Man's Avatar
DT 466Man
Why would it be time for a new clutch? it grabs just fine and it works perfect when i adjusted the pedal,but then gets mushy again. The truck is an 85 and it has the external slave cylinder. i'm thinking that the master cylinder or slace cylinder is going out.
77: It was a little loose so i tightened it up and i'll keep an eye on it.
Old Apr 19, 2005 | 04:15 PM
Torque1st's Avatar
Torque1st
Posting Legend
Moved to proper forum.
Old Apr 19, 2005 | 10:40 PM
jcdtjaj's Avatar
jcdtjaj
Red face Wanna change to auto trans
Can anyone tell me what type of auto trans I would need in order to swap out my 3 speed. I have a 65 F100 I6 2WD. Also, what about the drive shaft and how will this play on the rear end??
Thankx
Old Apr 20, 2005 | 07:50 AM
77300i6's Avatar
77300i6
You would want a C6 tranny. One from a windsor small block (289/302/351) should bolt up to your I6 (if you have a 240/300). Or if you can find one from a I6 that would work too. I'm not sure about the driveshaft and the gears should be ok. Do you know what gear syou have? I would think that with the 3-speed they would be higher than if your truck came with an auto.
Old Apr 20, 2005 | 11:02 PM
jcdtjaj's Avatar
jcdtjaj
When you say higher, do you mean more equipt for the hi-way? How can i find out about the gears in the rear end?
1990fordf-250
Dec 21, 2014 05:41 PM
LittleRedRanger4.0
Nov 14, 2012 07:52 AM
jbrune
Sep 25, 2006 02:35 PM
GaryJ
1983 - 2012 Ranger & B-Series
17
Mar 9, 2005 04:50 PM
1990350
Jul 14, 2002 07:56 PM
