77 460 carb/intake vs 84, HELP HELP!
Old Apr 17, 2005 | 11:51 PM
nsshull's Avatar
nsshull
Exclamation 77 460 carb/intake vs 84, HELP HELP!
I need help! HELP HELP HELP! 1: will an intake/carb from the 77 460 in an F250 bolt up to my 84 460 F250? 2: Which is a better combo?
Old Apr 18, 2005 | 12:04 AM
Bear 45/70's Avatar
Bear 45/70
Yes and they should be pretty much the same.
Old Apr 19, 2005 | 07:41 PM
nsshull's Avatar
nsshull
A little more help WOULD be nice....come on people!
Old Apr 20, 2005 | 12:01 PM
Hired Gun's Avatar
Hired Gun
Yes means, yes it will bolt up. It will run as good as it did before. Something better in my opinion would be a shiny new Weiand Stealth with a Holley 750 on top.
Old Apr 22, 2005 | 09:42 PM
Chiefrider007's Avatar
Chiefrider007
If I'm getting what you are asking the answer is, there should be no difference in the two. They should be practically, if not altogether, identical. No reason to change unless one is cracked or broken, something like that.
Old Apr 22, 2005 | 09:53 PM
Bear 45/70's Avatar
Bear 45/70
Right, unless something is wrong with what you have, don't bother.
Old Apr 22, 2005 | 11:50 PM
nsshull's Avatar
nsshull
the differences
The intake from the 77 is noticably a taller intake. and the 84 is a holley carb, not motorcraft.
Old Apr 23, 2005 | 01:13 AM
Bear 45/70's Avatar
Bear 45/70
But the difference in preformance and gas mileage will be nil.
Old Apr 23, 2005 | 12:52 PM
Icicle's Avatar
Icicle
Save your pennies for a Performer or a Stealth and an Edelbrock or holley carb.....
like the other guy said, you wont see any difference, I would imagine the EGR and emissions stuff may be a little different
