F150 swap
Old Oct 22, 2000 | 08:52 AM
pet31's Avatar
pet31
F150 swap
I have a 84 150 with a I-6, the fuel pump just went out on it and now the truck has a loud knock, I have narrowed it down to the fuel pump or a rod bearing, the oil was thin when I drained it. If it is the bearing can I swap this block for a 258 I-6 block from a jeep.
Old Oct 22, 2000 | 08:38 PM
bgodkin's Avatar
bgodkin
F150 swap
UUUUUUhhhhh. No. Apples to Oranges pretty much. A friend of mine just replaced his 300 I6 a little while ago and picked up one running from a junkyard for $125.00 Might want to look around and see what you can find. I would definatly try replacing the fuel pump. It sounds like a diaphram ruptured. If the gas has thinned out your oil too much it can make your engine knock due to poor lubrication. Change out the oil also.
Brad Godkin
1986 F350 CC/SRW
6.9liter/C6
Old Oct 23, 2000 | 04:15 AM
1985f150freak's Avatar
1985f150freak
F150 swap
chcknugget
Jul 26, 2012 10:45 PM
derk001
Jun 29, 2011 09:46 AM
fiftyfordfloored
Sep 4, 2008 11:02 PM
cyclone429
Oct 14, 2004 01:49 PM
1959ford
Jul 17, 2003 09:08 PM
