dome light short
Old Nov 21, 1999 | 04:31 PM
familyman's Avatar
familyman
dome light short
where do I begin in tracking down the short circuit in my dome light. Sometimes it works, sometimes not. Sometimes if I just tap the light it will work, sometimes a map light will work, but not the main light. Should I just replace the entire fixture? tighten wires? I don't believe the problem is in the headlight switch, but if you know something that I don't, I'm listening. Thanks.
Old Nov 21, 1999 | 08:50 PM
Pastmaster's Avatar
Pastmaster
dome light short
Family: I would look for a broken fuse, bad light, dirty connector, and the switches inside the door jams. Sometimes they stick!
Old Oct 22, 2000 | 09:22 PM
bgodkin's Avatar
bgodkin
dome light short
Try loosening and retightening the screws that hold it to the cieling. The dome light gets it's power and ground through them and they sometimes get crud built up in them.
Brad Godkin
1986 F350 CC/SRW
6.9liter/C6
Old Oct 22, 2000 | 11:39 PM
billyo's Avatar
billyo
dome light short
If you can tap the light fixture and make it work, you've already got it narrowed down. If it affects both the map and dome lights, it's probably a loose ground connection. I would remove the fixture and clean the mounting points.
O
Old Oct 23, 2000 | 10:57 AM
RGAZ's Avatar
RGAZ
dome light short
Your question is misleading unless you know these two definitions:
Short Circuit: When electrical current bypasses the load usually causing a fuse to blow.
Open Circuit: When a high resistance is present between the voltage source (or return) and the load that does not allow the load to operate as intended.
You never said you blew a fuse so I assume you have an intermittent open circuit. Trace the circuit path and remove the resistance, it is most likely the return (ground) path.
Randy
Sorry that sounds so blunt, but being an Electrical Engineer and hearing misused terms just drives me batty.
Old Oct 23, 2000 | 06:44 PM
kioolt's Avatar
kioolt
dome light short
My definition of a short circuit is "an unwanted path of current flow." I hear it used for every type of electrical problem that I am asked to repair.
Old Oct 23, 2000 | 11:03 PM
nitro94's Avatar
nitro94
dome light short
work.truck
Electrical Systems/Wiring
Dec 21, 2014 11:00 AM
Ordnance
Aug 18, 2014 10:59 PM
Shake-N-Bake
Oct 25, 2011 07:42 PM
01Foreman400
1983 - 2012 Ranger & B-Series
Jan 13, 2010 10:36 PM
fishel74
Mar 14, 2008 03:32 PM
