Oil & Lubrication
Mercon V for Dexron?
Old Apr 17, 2005 | 03:14 PM
MrBSS's Avatar
MrBSS
Since the "standard" automatic transmission fluid is for Mercon & Dexron specified transmissions, and Mercon V is apparently a better Mercon spec, does it follow that Mercon V can be used in a Dexron transmission?.... or, is Mercon V somehow different?
The reason I ask is that I got a lot of Castrol Mercon V (synthetic blend) on close out, and would like to make use of it in my Buick as well as my Ford. But if there's any question, I would just save it for the Ford.
Thanks,
Brian
Old Apr 17, 2005 | 06:25 PM
aurgathor's Avatar
aurgathor
It can be used, but you may have problems down the road. I'd stick to the recommended fluids. You can search this or the tranny forum for more info.
Old Apr 19, 2005 | 10:24 AM
MrBSS's Avatar
MrBSS
You are right. I've decided not to use Dexron/Mercon/Mercon V where Dexron is called for, even though the oil companies indicate its OK.
Here's why (from my owners' manual):
"MERCON and Mercon V type fluids are not interchangeable. DO NOT mix MERCON and MERCON V. Use of a transmission fluid that indicates dual usage (MERCON and MERCON V) in an application requiring MERCON may cause transmission damage".
Logically, since regular Mercon and Dexron seem to be similar, I believe one could also say that use of this dual usage fluid in an application requiring Dexron may cause transmission damage. In any event, it's a risk I don't want to take.
I think the explanation here lies in the older friction materials which apparently were attacked by some components of Mercon V. Quite possibly new Mercon V has changed that, but again, there's insufficient reason to take that chance.
Old Apr 19, 2005 | 10:29 AM
Saurian's Avatar
Saurian
Chevy's don't seem picky...as long as you change it.
That said...put what is recommended in there...
Old Apr 19, 2005 | 10:44 AM
daveee's Avatar
daveee
MrBSS. Could you tell us what Owners Manual you were quoting from? I have a bottle of Vavoline and a bottle of AAMCO Mercon V. Printed on both is a statment that they a certified for use where Mercon, Mercon V and Dextron III is specified.
Old Apr 19, 2005 | 10:51 AM
MrBSS's Avatar
MrBSS
Yes, the oil companies all say that, and maybe they're right. I just don't want to find out I got old stock or something, and then try to get reimbursed for a new trans!
My quote is from Ford "Owner's Guide F-150, 2001 Model Year".
Old Apr 19, 2005 | 11:54 AM
Casey's Avatar
Casey
My 2002 E350 owner's guide has that statement, too.
Old Apr 20, 2005 | 08:32 PM
Rockledge's Avatar
Rockledge
The Valvoline "Durablend" ATF that you are referencing is a dual-rated (Mercon/Mercon V) fluid according to Valvoline, not Ford, and in my experience it does not work well in a tranny requiring Mercon V:
https://www.ford-trucks.com/forums/s...2&postcount=12
Straight Mercon V is now easy to find on the shelves at most auto parts stores (I like Castrol Mercon V - it's recommended and approved by Ford) and is priced competively. So IMO there is no reason to take a chance with a dual-rated ATF fluid if your tranny calls for Mercon V.
derek0525
Aug 12, 2016 10:45 AM
tdpower
May 15, 2010 10:08 PM
tonyford
Escape & Escape Hybrid
Mar 15, 2006 11:21 PM
tnt4cat
Oil & Lubrication
13
Jan 7, 2005 07:25 AM
ruby2
Oil & Lubrication
Mar 14, 2003 09:16 PM
