Bed Covers, Tonneau covers, Toppers/Canopies & Bed liners Tonneau cover, caps, racks, canopies, shells, etc.
Drop in bed liner problem
Old 06-05-2005, 03:11 PM
RyanMiller's Avatar
RyanMiller
RyanMiller is offline
Hey, On my truck I have a drop in liner, and on the out most coners i have loop things that i use to tie stuff down, and they hold the liner in place. my current issue is that when it gets hot outside. the liner expands and ripples up in the middle. What can i do to anchor the sides of the liner down( it comes up on top of the bed rail) besides adding more loop anchors.
Old 06-05-2005, 04:24 PM
triton_2002's Avatar
triton_2002
triton_2002 is offline
You can try some 3M double sided tape and put it in between the liner and the bed rail.
Old 06-05-2005, 05:06 PM
RyanMiller's Avatar
RyanMiller
Ya think that stuff is strong enough? I was thinking maybe some sort of a bar on top but i think it wold look hack.
Old 06-05-2005, 05:19 PM
triton_2002
It's pretty strong stuff, just make sure it's the automotive grade used to stick on mouldings and stuff like that. You could screw some diamond plate or something similar on top of the rails too. The liner is probably flexing cause its too tight, maybe you can enlage the holes around the anchors?
Old 06-05-2005, 05:48 PM
RyanMiller's Avatar
RyanMiller
the holes are about 1 inch diameter, and the anchor's bolt is about 1/4 inch. When it was fully hot I loosend the anchors and tried to flatten the bumps and then tighten down the anchors again. Now when its cooler like at night, the ripples are practcly non existant, but when hot they are somewhat surpressed.. I'll check with a auto parts place for the 3m stuff and I'll put some weights on the ripples to keep it down... then worst comes to worse ill put some screws in haha.
chesster51
02-10-2015 01:27 AM
Rishsd
Bio-diesel, Propane & Alternative Diesel Engine Fuels
05-18-2013 03:18 AM
Livadia
23
02-19-2012 08:57 PM
bladez51
06-08-2011 06:26 PM
rangerxlt02
Paint & Bodywork
12-18-2004 07:25 PM
Quick Reply: Drop in bed liner problem
