Drop in Liner - wise to prep bed first?
Old Nov 5, 2004 | 03:31 PM
rangerxlt02's Avatar
rangerxlt02
Not much of an autobody person here, so bear with my question:
I have a drop in liner. Under rail from penda-liner. I went with that for my own reasons.
Would it be wise to prep the bed itself (metal) with something like zero rust and then drop the liner back in?
I don't want to find out that a few years later my bed is rusting.
Thanks for the input
Old Nov 11, 2004 | 09:22 AM
Autobodyforums.c's Avatar
Autobodyforums.c
Ranger,
Anykind of metal prep would be a good idea if you plan on installing that bed liner.
I dont use bed liners because im not all that rough on the truck in that case.
If i was going to use "ANY" kind of liner I do think i would shoot for a RHINO or the aftermarket do it yourself spray in liner. You'll get moisture under the other liners and the pray in is alot like the metal prep your going to be using anyways. The spray in liners are great from what i've seen and read reviews on.
All the best,
Matt
www.autobodyforums.com
Old Nov 11, 2004 | 09:49 AM
rangerxlt02
Yeah,
That is what I thought. I haul a lot of heavy things at the cabin and the drop in liner provides me with a bit more protection.
Thanks for the feedback on this. I'll look at prepping the bed and using an aftermarket DIY product to keep the rust from happenin'
Old Nov 11, 2004 | 10:48 AM
Huntsman's Avatar
Huntsman
I have never seen a drop in liner that didn't have rust under them when they were removed. They shift, slide and vibrate on the bed and hold moisture, eventually eating away the paint and rust is inevitable. The worst ones are the ones that extend up and on top of the bed rails.
Old Nov 11, 2004 | 09:59 PM
Autobodyforums.c
Thumbs up yeah man....
You is the MAN!!!!!
PREP that bed... Not meaining to post this but hook into this...
Its a DO IT YOURSELF Liner...
http://www.bestdarnparts.com/herculiner.html
For the Moneys i would same the bed if its in any good shape...
But if you dont care? Just install the Liner... This under the Liner may work for you also... Its Cheaper than a RHINO...
I've "NEVER" use this myself...I've just heard about it.
ANY "Autobody" or Automitive Store should carry such...
-Matt
Old Nov 12, 2004 | 09:41 AM
rangerxlt02
The bed itself is in perfect shape. I don't think the prior owner hauled anything heavier than blankets...hahaha.
I've got a cabin where I'm hauling crap around all weekend long (propane cylinders, split oak, air compressors, generators) so I threw in a drop in liner to help protect 'da baby' from dropping anything or scraping.
I'll give that herculiner a closer look. I think I've seen that at the local parts store.
Later
Old Nov 12, 2004 | 11:03 PM
Randle's Avatar
Randle
I have a 92 with a drop in liner that was put in when the truck was new. I can pull it out by myself in 5 min. or less, I do this a couple times a year and hose any dust off. There is just one small spot where it as rubbed the finish off. But one small rub in 12 years thats not bad. The good part I can pull it out and go back to painted if I want, and what does it do for your resale. I have used spray in liners on a couple of older trucks to hide alittle ruffness in the bed.
Old Dec 8, 2004 | 04:24 PM
JTDRanger's Avatar
JTDRanger
hey,
i just got a 93 ranger and want to line-x the bed. if the bed was rusty when i pulled up the plastic liner, would i have to address that before i got it sprayed? or would the line-x fix\halt the rusting? (basically, is it bad like painting over rust?)
Old Dec 18, 2004 | 07:25 PM
fearfactory's Avatar
fearfactory
Ive used herculiner and its some good stuff, it hasnt failed me yet.
maytag906
Aug 29, 2016 09:28 PM
300Jim
Bed Covers, Tonneau covers, Toppers/Canopies & Bed liners
Jul 30, 2014 01:27 AM
bladez51
Jun 8, 2011 06:26 PM
BlueovalFE
Jun 8, 2010 08:42 AM
Tod1985F250
15
Jan 30, 2009 11:49 AM
