I have an '87 Ford F250 with a 300 I6. I looked all over the axle and the differential and i cant find the stamping saying wut the gear ratio is. There is a metal tag on the differential cover but there is no gear ratio on it. If someone might have a good idea wut it could be(it is all stock no mods), or tell me where it is. Thanks
With 33" tires and 4.10s you should be turning about 2850 RPM at 65 MPH in your 1:1 gear. If your trans has an overdrive, you'll be turning a lot less, right at 2000 RPM if it's a 0.7:1 OD. Those numbers sound pretty good to me.
