Foot-feed cable
Old Apr 15, 2005 | 09:20 PM
biggut's Avatar
biggut
Question Foot-feed cable
Just got my fresh 390 bolted into my 66 F100 2wd. Now I'm not sure what to do for throttle-linkage! My 66 had the 300-6 cyl.with the cable. The 390 is set-up for linkage. I have all the linkage from a 73 F250 4wd, but I'm not too sure it will fit in the 66. I'm sure many of you have already solved this problem, and I'd really like to pick your brain! My 390 has a Holley 650. Thanks a lot guys! Brett
Old Apr 16, 2005 | 05:53 AM
jowilker's Avatar
jowilker
Hi Brett, I know the cable for the 6 is longer but you should be able to make it work. Ford went to rod linkages but went back to cable.
I think the ball fitting screws into the linkage. You should be able to transfer it to your new carb. IMHO
John
Old Apr 16, 2005 | 09:31 AM
biggut's Avatar
biggut
Thanks John, I'll give it a shot. Brett
Old Apr 18, 2005 | 01:13 PM
William's Avatar
William
"Foot Feed" Man that takes me back. I had not heard that one since I left Upper Michigan 40 years ago! Thanks for the flash back!
TheRedlines
Jan 27, 2017 08:07 PM
ggadwa
Jun 18, 2013 02:13 PM
55fordf100Gramps
Apr 11, 2013 06:20 PM
dyoungen
Feb 22, 2012 08:28 AM
carras
13
Jul 16, 2004 04:48 PM
