piston selection 400
Old Apr 15, 2005 | 10:30 AM
77NH Shortbox's Avatar
77NH Shortbox
getting ready to put my 351m back together. have a 400 crank, early cleavland 2v heads, decent cam, edlbrock intake and 600 carb. the block is 30 over. my question is what pistons to use. flat top? dished ? stock 30 over? anyone have a suggestion thanks in advance......
Old Apr 15, 2005 | 10:57 AM
Torque1st's Avatar
Torque1st
Posting Legend
Moved to proper forum.
Old Apr 15, 2005 | 02:50 PM
tastyklair's Avatar
tastyklair
Usually the easiest better than stock piston to find is the Badgers. They are a flat top and will bring your compression up to about 9:1 assuming you have not changed any of the other related parts, ie heads and block. There are a few places to get them. Do a google on Badger flat tops for a 400 ford.
Old Apr 15, 2005 | 02:59 PM
77NH Shortbox
hey thanks, however i have changed the heads to some 71 cleavland 2v heads so i still need to know whats the best choice..
Old Apr 15, 2005 | 03:27 PM
tastyklair's Avatar
tastyklair
That should not not affect the piston selection. The 2v cleveland head has a chamber that is 2.2cc smaller than the 400 head increasing the cr by about 1/3 of a point.
Old Apr 16, 2005 | 09:42 AM
bad as ford's Avatar
bad as ford
I am building the 400 in my 77 F250.
I am going to use Badger flat top pistons when they get here.
Found a set through an FTE site member and they should arrive soon.
I was lucky, In my search I called from Washington state to parts houses in New York and everyone was waiting for Badger to poor a new batch and get them out. One man I spoke with said he had three motors on stands waiting for those pistons.
Badger is the only maker of a flat top piston for the Ford 400 or 351m all the others are dish.
I am also useing 71 2v Cleveland heads on my build. Must have been a good year..
Get your order in ASAP...
Old Apr 16, 2005 | 09:51 AM
77NH Shortbox
thanks for the info guys... gonna get those Badgers comming.... does anyone know what the cr will be with the cleavland heads and the 30 over flat tops? thanks again.....
Old Apr 16, 2005 | 07:32 PM
tastyklair's Avatar
tastyklair
Should get you about 9:1 or just over. Go to www.kb-silvolite.com and use their calculator for cr.
Old Apr 17, 2005 | 08:25 PM
danlee's Avatar
danlee
According to Tom Monroe's book, the 351C-2V heads have 76.2 cc chambers compared to 78.4 on the 351M/400 heads. This should produce about 9.2:1 CR in a +0.030 motor.
79FordBlake
Sep 25, 2008 08:49 PM
79FordBlake
Aug 3, 2008 12:38 AM
mustange70
13
Mar 13, 2006 06:35 PM
danlee
33
Sep 25, 2003 06:59 PM
RWayneO
Jul 22, 2003 11:57 PM
