Oil Pressure Question
Old Apr 16, 2005 | 06:38 PM
bcboy4ca's Avatar
bcboy4ca
Hi everyone, I have a 1981 Bronco with a 351M in it. I was a little concerned with my oil pressure, the stock gauge read almost nothing once it warmed up. I just installed a mechanical gauge into the block between the fuel pump and the oil filter. It reads 75psi when the vehicle is cold and running at fast idle (approx 2100-2200 rpm). Once the vehicle is warm and it is idling at around 900rpm the oil pressure is at 25psi and it reads 10-15psi when warm and in gear. Does this sound normal because I am wanting to add some bolt ons to the engine for some more power but I don't want to be throwing money into a dying engine. Thanks for any replies.
Old Apr 16, 2005 | 09:25 PM
1979ford's Avatar
1979ford
Sounds like it has very good oil pressure, what add ons were you thinking of?
Old Apr 16, 2005 | 10:52 PM
fmc400's Avatar
fmc400
MSEE
I'm concerned about the reliability of your readings. The stock gauge takes its reading near the end of the oiling system, so it gives a "worst-case" reading and is what you should go by.
If I remember correctly, the plug you tapped into is located much earlier in the oiling system, and readings taken there will be higher than what the rear mains are getting.
Old Apr 18, 2005 | 12:09 AM
beeboy's Avatar
beeboy
Good point. I ran a T connector back at the rear block location and have both the factory guage and a mechanical there.
Old Apr 18, 2005 | 12:48 PM
bcboy4ca's Avatar
bcboy4ca
I recently read on another post in this forum that you could hook the gauge to either location and on initial start up the pressure would be higher at the front port but once the engine warmed up there would be no difference between the two. Did I mis-understand what the person was saying? I believe the post was called "Gauge connection locations" or something like that, it was within the last week that I read it.
