ignition timing set
Old Apr 14, 2005 | 01:39 PM
smoke n tires's Avatar
smoke n tires
ignition timing set
when you guys set up a straight up timing set on a later 70s 460 do you still set base timing the same? i have a early timing set in mine and i run about 12 degrees but at 2500-3000 im at like 45 degrees. i think my vac advance is causing to much advance. do you turn the screw in or out to lessen the amount of vac?
Old Apr 14, 2005 | 02:36 PM
wtroger's Avatar
wtroger
Sound like you need to chack the dist and make sure the mechanical advance springs are ok if they are streched or broken or came off it will allow to much advance and 45 degrees is to much. 30 to 32 is about max
Old Apr 14, 2005 | 07:12 PM
Bear 45/70's Avatar
Bear 45/70
Never check timing with the vacuum hooked up. The only time you do that is if you are checking how much vacuum advance you get. To do that at idle connect the vacuum advance to the manifold vacuum and read how much advance you have and at what rpm. Now disconnect the vacuum and run the engine at the same rpms and check the timing again. Subtract second number from first, will tell you how much vacuum advance you have. The reason you are seeing such a large advance is the mechanical advance is pretty much all the way in and the vacuum advance is seeing max advance also ( no load on engine = maximum vacuum). With no load on the engine this will generally hurt nothing. If you were driving down the road you would never see this much advance as you can't pull that much vacuum except on deacelleration and then ported vacuum would be closed and wouldn't matter anyway.
Old Apr 15, 2005 | 09:28 AM
smoke n tires
so to check total timing you disconnect your vac adv. completely? do you still set your timing at factory specs even if you installed a straight up timing set?
Old Apr 15, 2005 | 12:24 PM
Bear 45/70's Avatar
Bear 45/70
YES, always. How you set the timing chain and cam and crank relationship does not change the amount of timing you can run. That is a function of compression, stroke and the grade of fuel you are running.
Old Apr 15, 2005 | 06:25 PM
quehele's Avatar
quehele
Just a thought...adjust the vacuum module?
I just replaced the vacuum advance module on my 77 F250 with a 460 and had to adjust the vacuum module. If you insert a 1/8" allen wrench into the advance module through the nozzle you'll find a set screw. The instructions that came with my vacuum module say to set it the same as the one you're replacing. It says to screw the set-screw in as far as it will go then back it out the same amount as the original.
Mine was 5 full turns out from the bottom.
Hope this helps some.
Jim
Old Apr 15, 2005 | 06:33 PM
SwOkcOffRoader's Avatar
SwOkcOffRoader
dont the older 460s have less advance?? im working on a 71 lincoln mark III at the shop i work at, the sticker on the 460 in it calls for 4 degrees BTDC at 600 rpms, my 78 model 460 calls for 12* BTDC at 650 rpms, so wouldnt any 460 with the earlier timing set need to be set at 4-8* BTDC??? if so, what would the total advance be??
Old Apr 15, 2005 | 06:54 PM
Bear 45/70's Avatar
Bear 45/70
The initial advance setting depends on how much mechanical advance is built into the dist. You have to pull the base plate to see what the mechanical advance is set at. My 1984 F250 was on the 18 degree advance curve. The curve not used was 13 degrees. I reset mine to the 13 degree curve and an now able to run more initial advance. Some of my old 428CJs from the late 60's had 13 and 10 degree advance curves in the dist. but those were true preforamnce engines.
