Head Bolts
Old Apr 15, 2005 | 02:32 PM
460gould's Avatar
460gould
Head Bolts
I need to retorque the headbolts on my 73 460(from a lincoln), but there is no way to get around the rocker arms. What is the easiest way to remove the rockers to do this?
Thanks
Old Apr 15, 2005 | 02:34 PM
wtroger's Avatar
wtroger
Why are you retorquing? Most of todays head gaskets don't require it.
Old Apr 15, 2005 | 02:41 PM
460gould's Avatar
460gould
well, basically because when I bought this engine from a friend, I was told it was ready to go. So I did not check to make sure that anything was torqued correctly. A couple weeks later, I have developed a leak between the block and head. So I stuck a torque wrench on it, and found out that they were nowhere close to what they should be(the bolt I stuck it on was only 60lb-ft). So I wanted to torque them down correctly before I something else blows.
Old Apr 15, 2005 | 09:48 PM
wtroger's Avatar
wtroger
ok that makes sense.
Old Apr 15, 2005 | 09:57 PM
frederic's Avatar
frederic
A very short socket with an extension should do the trick. A few years ago I cut down a set of old sockets for jobs like this - and I used old sockets because cutting them down also got rid of the damaged ends too, allowing me to "recycle" junk.
I cut them down to about 7/16 of interior length, not quite 1/2".
