Sponsored by: Real Truck
Tips for removing SD bed
Old Apr 14, 2005 | 01:38 PM
VIKING24's Avatar
VIKING24
I'm looking to remove the bed on the 00 SD SC shortbed and unfortunately dont have access to a garage, lift or a lot of help. I'm thingking about using a sizable tree limb to through a cable over, and attach a cable puller and tow straps to the factory tie downs, remove the bolts and lift it up, drive the truck out from under it and lower it onto jack stands. Any one know what the 6ft bed might weigh? Any one else do anything like this or am I setting my self up for an appearance on Americas funniest videos?
Old Apr 14, 2005 | 02:09 PM
MARZ06's Avatar
MARZ06
My suggestion is....set up a camera and tripod. You never know, it might be worth the $10K on AFV.
Old Apr 14, 2005 | 02:18 PM
Texascadillac42's Avatar
Texascadillac42
Remove the 6 bed bolts, wiring harnesses for hte rear taillights, take off hte tailgate, and take off hte fuel filler nozzles. 2 guys can lift the bed off at this point. It is lighter than you think, and with the tailgate off, it is very easily balanced. If you cant get a friend to help, then yes, 4 equal length ropes from each corner, tied to a single rope from above, should lift the bed off no problem. I dont know the exact weight, but a friend and I lifted it off no problem at all.
Old Apr 14, 2005 | 02:32 PM
VIKING24's Avatar
VIKING24
Ropes...check
Cable...check
Tree...check
Wife to operate camera...check
Full coverage health insurance...check
Sounds like my evil plan may actually work.!
Thanks for the responses
Old Apr 14, 2005 | 03:59 PM
Yeti's Avatar
Yeti
I ended up drilling all but 1 bolt out on my 01, I got fed up after snapping 5 or 6 torx bits off.
Old Apr 14, 2005 | 08:32 PM
99f350sd's Avatar
99f350sd
I had to grind my bolts off. The long bed was heavy but not too bad. 4 guys and its a breeze. Don't forget the fuel hose.
Old Apr 14, 2005 | 11:21 PM
Texascadillac42
Yea, I drilled 4 of my 6 out. With a sharp bit and some cutting oil a good drill will blow right through those heads in no time.
Old Apr 15, 2005 | 08:08 AM
VIKING24's Avatar
VIKING24
Did you guys have to just drill ou the heads or did you have to drill the bolt out of the frame??
Old Apr 15, 2005 | 10:10 AM
Yeti's Avatar
Yeti
If I remember correctly, you have to drill at least half the bolt out, due to the shank of the bolt being thicker at the head.
Old Apr 15, 2005 | 10:25 AM
Donutrcng's Avatar
Donutrcng
Texascadillac42 is correct - 2 guys can lift off the bed one the attachments and filler neck is disconnected. I did an 02 SB this way. No problems.
Old Apr 15, 2005 | 02:05 PM
ColtM4's Avatar
ColtM4
My bolts unscrewed just fine when they line-x the bed, buy my dads 94 we removed all but one, and had to use a grinder to remove the last one. Maybe you need better torx bits, or maybe they were rusted in.
Old Apr 16, 2005 | 07:54 AM
Yeti's Avatar
Yeti
I'll tell SnapOn to look into it
dennisb56
25
Aug 29, 2014 07:09 PM
Nader
Aug 2, 2010 12:16 PM
BFR250SD
Sep 26, 2005 02:25 AM
BroncoRoadKill
1978 - 1996 Big Bronco
Mar 28, 2003 11:04 AM
