300 has no power?
Old Apr 13, 2005 | 11:35 PM
rshissler's Avatar
rshissler
300 has no power?
My 300 in my '84 Bronco has no power what so ever. It just doesn't have any pick up and go. It's extremly slow at picking up speed, slower at pickin up speed then my 300 in my truck. It loses so much speed goin up the smallest of hills. Ill have it in 2nd gear and it will have alittle go, shift into 3rd and it will die al together. Anything i can do to give it some boost?
Old Apr 13, 2005 | 11:36 PM
rhetor's Avatar
rhetor
whats the rear end on that puppy?
Old Apr 14, 2005 | 12:20 AM
rshissler's Avatar
rshissler
stock lol havn't really got into anything on it yet so yea lol i know its stock so maybe a 9"
Old Apr 14, 2005 | 10:31 AM
rhetor's Avatar
rhetor
I meant what gear ratio is it?
If the truck has towing gears and the van has highway gears, that will make a huge impact on acceleration.
Old Apr 14, 2005 | 11:07 AM
rshissler's Avatar
rshissler
o lol dont know that either, it has a tow ball on it and the guy used it for offroadin and fishing and has 32" tires
Old Apr 14, 2005 | 11:41 AM
77300i6's Avatar
77300i6
Smile poor accelaration
What condition is your ignition in? I would check plugs, wires, cap, ect. Also check your timing and make sure your carb is tuned properly.
If the PO used it for towing the clutch may be slipping or burnt. Anyone of these things(plus incorrect gears) will make pi$$ poor performance.
Hey I just made my 300th post in the inline forum
Old Apr 14, 2005 | 02:00 PM
rshissler's Avatar
rshissler
lol ok congrads on the 300th post
Yes the clutch needs replaced i know that, the plugs and wires i changed but i need to look at the cap and rotor, I'm gonnin to work on tunin the carb tonight. What should it idle at?, i"m gonna get my freind to check the timin this weekend. It idles alittle rough and it will stall when u start it up unless u give it some gas for alittle then it will run fine. and also that annoyin whistnin noise from somewhere around the carb area and the really bad "run on" condition.. I posted about them before
Old Apr 14, 2005 | 02:57 PM
Gerry Lutz Jr.'s Avatar
Gerry Lutz Jr.
The whistle is probably some sort of vaccum leak which could lead to all kindsa things including your truck being sluggish and tough to keep running when its cool . Be sure to check your vaccum for leaks.do you run cats on it?does it seem to be running rich all the sudden? If so check to make sure your cat isn't clogging up you will usually notice a lot of heat in that situation though. i'd probably check your carb and timeing and ignition as the others said first though.
Old Apr 14, 2005 | 03:01 PM
rshissler's Avatar
rshissler
yea it seems like the engine runs rather hot right after it starts but the temp gauge says its on the lower side of normal. the whistle noise doesn't start untill the engine gets alittle warm
Old Apr 14, 2005 | 03:19 PM
MRStace84's Avatar
MRStace84
Check for vacuum leaks and your timing. At one point my intake was leaking and my truck ran like a slug.
After that you may need to rebuild or replace your carb.
Old Apr 14, 2005 | 03:54 PM
rhetor's Avatar
rhetor
now its 302.
Old Apr 14, 2005 | 04:38 PM
rshissler's Avatar
rshissler
u went from one engine to another lol jk
Old Apr 14, 2005 | 08:23 PM
rshissler's Avatar
rshissler
ok i set my trip thing on the gauges and i drove 22 miles and used 1/4 tank with a 19 gallon tank (i think) 4 MPG!!!!
B_line66
May 21, 2014 08:37 PM
70BumpClubCab
15
Apr 4, 2013 11:44 PM
wookie770
Aug 14, 2012 09:20 AM
69 F-350
May 23, 2008 12:18 PM
Outcastz89
Apr 14, 2008 04:26 PM
