np435
Old Apr 13, 2005 | 05:20 PM
ubenbunkered's Avatar
ubenbunkered
np435
i have a np435 out of my 79' f150 the shafts are a little wobbly does it need to be rebuilt or is this normal? Is rebuilding it very hard?
Old Apr 13, 2005 | 10:49 PM
Hooker Bob's Avatar
Hooker Bob
A little wobbly umm a small amount of slack in the input shaft is normal. remember that the pilot bushing or bearing helps supports this when in place. What I look for is any roughness while rotating the shaft checking it in all gears. The draining and examining the grease is the best way tell what shape your trans is in. Lots of metalics and you can be sure it needs attention. Also look at bearing races they should be shiney if they have a frosted or matte look, they need replacement. Look the gears over closely any pitting, teeth missing, edges worn or discoloration.
Pat
Old Apr 14, 2005 | 02:09 AM
"Beemer Nut"'s Avatar
"Beemer Nut"
While your out, top off, check the clearances for the synchros. Set them on the low side of clearance with the steel shims. You want "detectable" input shaft end clearance, too tight and the thrust bearings will bind up with crunchy shifting. Too loose and the box will rattle as well as the taper input bearing will allow excess gear mesh clearance. Before installing the shift cover, replace the nylon shifter fork pads with new. The intermediate ball bearing will make noise and get loose with mileage or agressive driving, it's a 308L number. Standard is 7 ball (weak), get a 11 ball it's stronger. As posted above a good clutch, no reman pressure plate. Cheap baskets are stamped from thinner metal, they can crack if your motors strong or agressive driving. Replace pilot bushing and throw out bearing. Getting too long, sorry.
Carl....=o&o>....
petrovich79f250
Dec 19, 2020 09:37 AM
OzFTrucker
Nov 30, 2013 04:25 PM
ManfredVonRichtofen
WTB - Parts & other
Nov 13, 2013 02:50 PM
86fsbronco
1978 - 1996 Big Bronco
Dec 24, 2011 01:49 AM
kingford72
Jul 19, 2011 09:02 PM
