Changing Temperature sender- drain coolant?
Old Apr 12, 2005 | 07:21 AM
trucklen's Avatar
trucklen
I have to change the temp sender in my 96 EB OHV V6. Can I do it without draining any coolant? I'm thinking I can do a quick swap and keep my finger over the hole when I quickly switch the parts. I can keep coolant loss to a minimum that way......or do you have to drop the coolant level...
Old Apr 12, 2005 | 08:41 AM
Racerguy's Avatar
Racerguy
I do it the way you're thinking of trying but first make sure you open the rad cap to let any pressure out and then install it again.
Old Apr 12, 2005 | 09:02 AM
trucklen's Avatar
trucklen
Thanks, I'm also planning on doing it after leaving it sit overnight. Is teflon tape a good sealer for this purpose? That is what the manual suggests.
Old Apr 12, 2005 | 10:16 AM
Racerguy's Avatar
Racerguy
It should be a tapered type of brass fitting so no extra sealer is needed.
Old Apr 12, 2005 | 02:48 PM
AlfredB1979's Avatar
AlfredB1979
What my brilliant stepdad suggested after I drained the coolant, put a load of paper towel in the funnel when I poured the coolant back in to filter all the crud from the drain pan and whatnot.
Worked great as I saw what all got caught by the makeshift filter....and either the 2.3L is that tough (yep) or the trick worked.
In theory, if the sensor is easy to get to, plug up with a finger, but mine was a REACH and the coolant poured out fast enough to pop the sender back out until the level dropped in the block.
sneltyr
Mar 11, 2016 07:01 AM
khs2671
1997 - 2003 F150
Apr 5, 2012 11:56 PM
ptf18
1983 - 2012 Ranger & B-Series
Mar 27, 2012 06:43 PM
BigBlue92
Mar 27, 2011 09:10 AM
SSSimon
18
Oct 25, 2010 07:21 AM
