Cam Question
Old Apr 12, 2005 | 12:37 AM
oricle's Avatar
oricle
Cam Question
Well I contacted a chip manufactuer, and they told me before I order a chip I should know what cam I will be using. I am running a 91 EFI 460 and am curious as if this will be ok and not throw off the speed density computer?
CLASS I CLEVITE 77 CAM, 16 NEW LIFTERS, HD CLOYES TIMING SET, NEW CAM CHANGE GASKET KIT FROM FEL PRO, AND A CONTAINER OF COMP CAMS CAM LUBE
#229-1732 PERFORMANCE CAM - NEW IN BOX - CAM SPECS 204/214 DURATION @.050
270/280 ADV. DURATION
490/516 LIFT
CENTERLINE 112
I also have a twin BBK throttle body on the way along with a Adjustable Fuel Pressure Regulator. Will this cam run fine? Will I want new springs with it?
Old Apr 13, 2005 | 09:23 PM
built4wheelin's Avatar
built4wheelin
i can't tell you if that cam will work or not - you need to call the cam help line of a reputable cam grinder. but i would say get new matched springs for sure. you didn't say how many miles are on your current springs, but anything over 60,000 miles- if it is coming apart- might as well replace them. and since the cam is larger than .500" i would say get the correct matching springs anyhow...
let us know how it runs.
Old Apr 13, 2005 | 09:30 PM
oricle's Avatar
oricle
Called up comp cams a hour or so ago. They have a cam made for the SD computer. $194.00 and he said I will need matching lifters which is another $84.00. Am I gonna wanna get springs also or will lifters+cam be fine? He said this is all I need.
ROADHOGE250
Mar 24, 2019 06:55 PM
Micbruff
23
Nov 5, 2014 08:17 PM
ToMang07
Jun 19, 2011 10:58 PM
ToMang07
Jun 4, 2011 03:04 PM
ToMang07
May 29, 2011 10:43 PM
