Timing setting for 460
Old Apr 12, 2005 | 06:24 PM
Aussie's Avatar
Aussie
Smile Timing setting for 460
G'Day All
I just got myself an Old Ford F-150 with a 460 motor in it and was wondering what the timing should be set at.
Me being from Australia and living in USA now I don't know alot about 460s They are like hens teeth in Aussie
Thanks for all who can help
Old Apr 13, 2005 | 08:16 AM
smoke n tires's Avatar
smoke n tires
older like up to 74 i believe is 6-8 degress and 75 to early 80s is 12-14 degress.
Old Apr 13, 2005 | 09:05 PM
Chiefrider007's Avatar
Chiefrider007
Put her on 10. Really though, as they get older the timing chain stretches and right on the mark isn't always right for every engine. Tuned for your engine, this is for everone, advance the timing, a little at a time, until the engine starts to spark knock/ping under a load, then back it off/lower it, a little at a time, just until the knock stops. If you later check it with a light, it will be within a couple of degrees of what it's supposed to be. If it's not, either you have some serious problems about to occur or you have already made some serious changes.
Old Apr 14, 2005 | 09:06 AM
Chuky66's Avatar
Chuky66
If you have the time, put a aftermarket timing set in her, set straight up, and you'll be pleased!!
C-
dimora
22
May 30, 2016 09:41 PM
GB SISSON
1947 and Older Ford Trucks
Jan 24, 2016 08:46 AM
Kruse
13
Nov 30, 2014 04:59 AM
OzF250
New Member Introductions
Jul 14, 2014 03:15 PM
