Sponsored by: Kumho
Leaf spring bushings
Old Apr 11, 2005 | 10:54 PM
subnet76's Avatar
subnet76
I need to replace my leaf spring bushings on my 95 ford f-150 2x4. I was wondering if I have to have them pressed in or can i use a hammer? Also where would I go to get a set of over load leafs?
Old Apr 12, 2005 | 08:20 AM
mark a.'s Avatar
mark a.
They old ones have to be pressed out. Polyurethane replacements slide in, stock ones will have to be pressed in as well.
Old Apr 12, 2005 | 08:22 AM
Spaznaut's Avatar
Spaznaut
Get out the drill to hollow out the old bushings to get em out. That or a torch is the good 'ol redneck method of removal. Need to do this myself Maybe after I fix the wifes car.
Old Apr 12, 2005 | 11:04 AM
ivanribic's Avatar
ivanribic
Don't do this! Leaf springs should never be heated. It can cause them to fail and break making it especially dangerous to do at the eye. If you don't have a press you can use a big C clamp and some sockets to push the old bushing out and the new ones in. It takes a good amount of leverage on the C clamp though. Otherwise if you pull the whole spring a good bench vise will work nicely also.
Old Apr 13, 2005 | 12:27 AM
subnet76's Avatar
subnet76
I guess I'll go with the poly bushings, seems like it would be the easier route.
Old Apr 15, 2005 | 10:57 PM
subnet76's Avatar
subnet76
Where can I get a set of the poly bushings at, fast? Also Is there any other bushings under there I should go ahead and replace while I have them out? I do quite a bit of heavy hauling.
Old Apr 16, 2005 | 08:40 AM
mark a.'s Avatar
mark a.
Summit would be the fastest that I know, don't know about Jeffs B.G.Y.
Old Apr 16, 2005 | 03:05 PM
subnet76's Avatar
subnet76
I looked around summit but I couldnt find anything for my truck, only mustang.
Old Apr 17, 2005 | 11:23 PM
subnet76's Avatar
subnet76
Has anyone else done this? Im going to replace them this weekend. I went ahead and bought the 4 bushings for the springs and the 2 for the ones that actually mount to the frame as well. Im also going to purchase an "add a leaf". I guess this will help out a bit on a heavy load. I hope all of this takes care of the popping.
Old Apr 18, 2005 | 11:11 AM
brokebronco's Avatar
brokebronco
Try these
http://www.truckperformance.com/prod...ring+Bushings/
http://broncograveyard.com/products/cat/20/168/33156
Chris
Old Apr 25, 2005 | 10:56 PM
subnet76's Avatar
subnet76
Is PROTHANE a good product for leaf spring bushings? It is what I purchased, I just want to know if this is a pretty legit company.
Old Apr 26, 2005 | 06:38 PM
1984F15016's Avatar
1984F15016
i dont know if i am too late to add my 2 cents, but when i took my old bushings out i used a wheel puller and an impact gun. It worked pretty well. when you install the new ones put them in the freezer for a while before, it will make it easier.
Old Apr 26, 2005 | 09:09 PM
HOWiseJR's Avatar
HOWiseJR
Smile 1984f15016
Thanks for the good info on wheel puller and empact gun.
Old Apr 26, 2005 | 10:29 PM
subnet76's Avatar
subnet76
Good idea with the wheel puller, I guess Ill ice up the bushings along with my bevrages now. Get them all ready for the weekend.
kioolt
Oct 25, 2013 05:12 PM
spinella
Mar 23, 2010 08:42 PM
Lightning54
1978 - 1996 Big Bronco
Jun 13, 2009 01:20 PM
twobitranch
Mar 26, 2007 09:06 AM
Christopher2
Nov 13, 2004 07:48 AM
