slam time
Old Apr 14, 2005 | 10:56 PM
Almost_A_Merc's Avatar
Almost_A_Merc
Carl,
After looking it over tonight a bit while working on my trans seal, I think there should be sufficient strength there to allow the perch to be in tension. My intent was to set that top bolt going through the spring as close to the bed floor as possible. I was hoping to lower it about 4 inches, and as you had mentioned us wedges to correct the pinion angle.
More later, just trying to collect info for now...
God Bless
David
Old Apr 15, 2005 | 02:49 AM
"Beemer Nut"'s Avatar
"Beemer Nut"
Almost, the biggest worry I see is the wave on the frame around both sides of the front perch. With the taper of the perch mounting surface inverted, wide on the bottom and the frame narrow on the bottom you will cross over the wavey frame. Last night in the dark I did a quick measurement and that would relocate the spring eye by 8 inches or 4 inch rear drop. I would like to get a 2 1/2" rear drop. Just to level the truck, easier to load a motorcycle. Is the perch different on different years of trucks besides wider springs? I see a trip to Pick N Pull in the near future. Keep us posted on what works.
Carl....=o&o>....
67highboy
May 21, 2015 09:54 AM
wes_d03
33
Jan 2, 2013 09:16 AM
part timing
Jul 9, 2012 06:56 PM
JoeVR5
17
Feb 16, 2010 08:57 PM
berry1234
Jun 21, 2007 03:13 PM
