steering linkages
Old Apr 11, 2005 | 11:47 AM
ranger240's Avatar
ranger240
steering linkages
hey all!! so here's the thing... I have a 68 F100, with 73-79 disk brake front end under it. I need to get new steering parts (all of them)...
so my real question is.... Will the parts all interchange from 73-79, or are there different part numbers for the steering linkage? I plan on getting new dropped I-Beams so king pins and spindle bushings will be covered then. I just need to know about the drag link, and tie rods and ends basically.
thanks for any help..... _Ken
Old Apr 11, 2005 | 01:39 PM
73Custom's Avatar
73Custom
The book I have lists all '73-79 F100-F150 2wd as having the same drag link and tierod ends. The 4x4s and F250-F350 are different.
Marty
Old Apr 11, 2005 | 01:44 PM
ranger240's Avatar
ranger240
thank you very much, marty. next question.... who would have these parts (on or off line) at a greatly discounted cost? I have been looking on ebay and found a few, but shipping will make it cost more than if I just bouth it here in town, which I will probably do anyway.
thanks again
_Ken
Old Apr 11, 2005 | 02:15 PM
73Custom's Avatar
73Custom
Any auto parts store can get them. I use the local NAPA, but they're not always the cheapest.
Marty
Old Apr 11, 2005 | 03:45 PM
oldhalftons's Avatar
oldhalftons
If you get dropped I-beams you will need an adjustable draglink. or your pitman arm will be clocked to far to the passenger side. and there are only adjustments for placement on the steering box at 90 degree intervals. also the inner and outer tierod assembly will have to be assembled too long.
you'll end up with a truck that will barely steer left and over steer right.
all the stock parts are the same 73-79 f100, F150, f250 under 6800lbs (or with single piston brakes)
Old Apr 11, 2005 | 05:28 PM
ranger240's Avatar
ranger240
I went to Oriley's, got all the parts plus new front wheel bearings, and races for $130. I think that's fair enough.
the Chassis Tech dropped I-beams I am getting also have the tie rod relocators (at extra charge). I spoke with their tech, and he said it takes care of that problem, so I should be golden in that department. anyone on here have any first hand experience with the Chassis Tech I-beams? I would love to see some pics of the results. or could you refer me to another company (I wasn't to pleased with the DJM parts, just personal prefference, though they would give better ground clearance.
there aren't just a whole lot of people doing this kind of drop, most are going to a mustang II IFS setup, which is cool, but I want a product designed for a 4800# FULL SIZE TRUCK, not a 3000# oversized pinto (no offense mustang guys, I like the '70's 'stang more than most.)
_Ken
77&79F250
153
Dec 28, 2013 09:00 PM
Papa'sPride
30
May 4, 2010 07:43 PM
fisher_of_man
Nov 16, 2007 04:31 PM
jlasater
17
Aug 23, 2004 01:53 PM
mike79ford4x4
Jan 13, 2004 08:22 AM
