Smog pump
Originally Posted by hawk242
Defines Efficently as what fuel the engine converts to power. What the converter does is burn off excess gasoline that makes it by the engine, it does this by heat... a lot of heat.
Yeah, guys, the last of the Broncos got injectionless cats that are considered more efficient than the earlier versions so in that case you don't need the smog pump...technicalities don't change the FACT that without air injection on trucks equipped with it, you WILL get erroneous readings from the O2 sensor.
The "crude oil" pumped out of the ground is a black liquid called petroleum. This liquid contains aliphatic hydrocarbons, or hydrocarbons composed of nothing but hydrogen and carbon. The carbon atoms link together in chains of different lengths. It turns out that hydrocarbon molecules of different lengths have different properties and behaviors. The purpose of air injection is the same as adding oxygen to a torch it consumes more O2 and gets hotter. and burns more, "hydrocarbons".... BTW my 93 Fiestva (AKA. KIA) has its converter between the engine and the radiator.
I wanna take about cool stuff now, like Broncos.
Richard Gaytan
10-21-2015 04:03 PM
armashby
07-24-2015 10:54 AM
