Sonnax Valve/Spring kit DONE!
Old Apr 10, 2005 | 08:22 PM
Pocket's Avatar
Pocket
Yep, finally got to it and did it today. Had to first find the time to do it, then had to find a torque wrench. Found a Pep Boys here that loaned me a torque wrench. It was time to change the tranny fluid and filter anyway. Old fluid that came out looked brand new and there wasn't much metalic gunk on the magnet at the bottom of the pan. That's always a good sign in my book
It was messy and a little time consuming, probably because I wanted to make sure everything was done perfect. The Sonnax valve and the springs are an easy install. Truck shifts perfect now. No more gliding into gear, just a nice and firm little bump that you feel as it shifts. Well worth the mess and time spent.
Now on to more mods!!!!!
Old Apr 10, 2005 | 08:28 PM
Duane99's Avatar
Duane99
Sounds good pocket, I havent found the time to do mine yet but the kit is here waiting. Weather has been really bad, woke up to 1' of snow today brrrrrr. Maybe next weekend
Old Apr 11, 2005 | 08:26 AM
rmilchman's Avatar
rmilchman
I was thinking about doing the valve in my '02. What was involved in the install? Can I screw it up?
Old Apr 11, 2005 | 08:37 AM
arninetyes's Avatar
arninetyes
Originally Posted by rmilchman
Can I screw it up?
If you want to and try hard enough, yes.
Just follow the directions, have a proper inch-pound torque wrench, and be prepared for the mess...
Old Apr 11, 2005 | 09:03 AM
Pocket's Avatar
Pocket
Taking everything apart and putting it together was straightforward and very hard to mess up anything. The only tough part I had was getting the line pressure modulator valve bore and the spring valves out. They didn't want to come out easy, but I did carefully work them out.
On a 10 point scale (1 being easy and 10 being the worst) I'd give it a 2 for installation and a 10 for the mess.
Oh, and having a 6 inch lift made it the perfect height to crawl under and work on the tranny
Old Apr 11, 2005 | 10:18 AM
wycowboy's Avatar
wycowboy
Wiould this help with trany longgevity?? Ive been looing at the kit and cant tell if it is just a porformace mod or a durability thing? thanks all J
Old Apr 11, 2005 | 10:26 AM
Spirit615's Avatar
Spirit615
Where did u get your kit from?
Old Apr 11, 2005 | 10:37 AM
arninetyes's Avatar
arninetyes
wycowboy, the shift kit should help with tranny longevity. By making the trans shift more quickly, you accomplish two things that help it to last longer:
1) - you reduce wear on the clutches because they don't slip as much or as long as with the stock setup; and,
2) - by reducing the slippage, you reduce the heat the trans produces, keep the temp cooler, and prolong the life.
The biggest enemy of an automatic transmission is heat. The shift kit is good, but also make sure you are keeping the trans temp low - a trans temp gauge will help you keep track of this.
Old Apr 11, 2005 | 10:50 AM
arninetyes's Avatar
arninetyes
I rarely tow, and have never towed anything over 6,000 pounds with my truck. But I'm paranoid about the auto trans as I have never trusted them (My first car had an automatic - had to have it rebuilt twice in the 50,000 miles I owned it. My second one had an automatic. I bought it, serviced it immediately. Everything looked fine. 10,000 miles later it died. I switched to manual transmissions and never looked back).
On my F250, I have the following to help the trans last longer:
1) shift kit
2) extra capacity, finned aluminum trans oil pan
3) external trans filter (with filter bypass, to prevent trans destruction if the filter should get clogged)
4) replaced the stock lame trans cooler with a Tru-Cool cooler.
Seems to work fine. By the way, performance is also helped. My truck used to "slide" from first to second gear when pushing it at all. Now it just makes quick, solid shifts. Well worthwhile from a performance standpoint, even if it didn't help keep the trans alive longer.
Old Apr 12, 2005 | 08:29 AM
rmilchman's Avatar
rmilchman
I have never been inside a tranny. How long should I expect the install to take?
Old Apr 12, 2005 | 11:22 AM
bigdaddyTank's Avatar
bigdaddyTank
It only takes about an hour if you take your time and double check everything. I spent extra time cleaning the pan up, but its not a hard thing to do at all. The key is no rushing and keeping everything clean. Its a great upgrade and will make you smile the first time you feel the difference in shifting. Its been a couple weeks and I'm still smilin.
Old May 9, 2005 | 08:01 AM
rmilchman's Avatar
rmilchman
Where is the best pace to order the kit from?
Old May 9, 2005 | 08:23 AM
Robbgt's Avatar
Robbgt
$50 at blackclouddiesel.com.... (cut and paste the link) i think that includes shipping...
-Robb
Old May 9, 2005 | 08:47 AM
rmilchman's Avatar
rmilchman
Thanks, just placed the order.
Rich
Old May 9, 2005 | 08:57 AM
mtncrawler's Avatar
mtncrawler
On the E4OD when doing this mod is a new gasket for the valve body required? Or is there one?
