speedometer issue
Old Sep 28, 2012 | 12:18 AM
bigjohn57's Avatar
bigjohn57
speedometer issue
i have a 1978 f-150, i had to remove the insturment cluster to repair some wires. when i put it back together, my speedometer is off by about 30 mph. how do i set it at zero and then keep it at zero until i put the speedometer cable back in.
thank you
John
Old Sep 28, 2012 | 07:27 AM
jim collins's Avatar
jim collins
I'v had a lot of these gauge clusters out and never had that to happen. Did you drop it on the floor or take the speedometer apart ? When you say it's off by 30 miles ,do you mean the needle is stuck at 30 and won't drop on down to O ? If that's it you may have to remove the needle and reset it on O .
Old Sep 29, 2012 | 05:42 AM
bigjohn57's Avatar
bigjohn57
no i didnt drop it or even take it apart,when the truck is not moving the needle points straight down not even close to zero. i dont know how to set it on zero. is thier any hope
Old Sep 29, 2012 | 07:49 AM
77F150Jason's Avatar
77F150Jason
Mine dosen't work at all. I just use a free speedometer app on my phone that works off the gps. then you don't have to worry about switchng speedo gears with differant tire sizes. just my 2 cents
Bronchole
May 22, 2018 01:14 AM
PA F250
17
Aug 28, 2013 06:35 AM
jimbob21rc
Mar 14, 2005 06:36 PM
