I wonder who that was? I was debating on whether to explain the fix or not, after what I put all who responded through. But I read a comment on this forum where everyone states what the problem is but never finishes the thread by telling what fixed it, so I did. Even as embarassing and stupid as it was on my part.
(Man, I still know I pulled all the fuses. Ha!)
Thanks for letting us know. You can look on the bright side and know that someone else will have the same problem in the future and they will remember reading this thread!
Excellent point. Other items include: Fuel Heater,Wastegate Solenoid,and Injector Driver Module Relay Coil. You probably want to test and take a look at the wireing on those items.
I was thinking the Fuel Heater was on that one. I would bet the Heater has shorted out and the fuse will blow again before long. Unplug the heater at the fuel bowl until you get a chance to change it out.
Well, I have two possibilities. One is when I changed my fuel filter a couple weeks ago, I used a rag and a screw driver to try and clean up some of the crud on the bottom of the bowl. I may have jarred something with the fuel heater. Possibility two, while I was cleaning out wire harness connections on the driver side, under the hood, there was one that did have fluid in it. That kinda surprised me. But soon after I bought this truck 8 months ago, I found it had a leaking hydroboost. So who knows how long that hydroboost had been dripping powersteering fluid on the connections. So that connection may have just finally shorted out.
