replacing serpentine belt?
Old Jan 3, 2001 | 01:37 PM
f150 female's Avatar
f150 female
serpentine belt seems cracked and worn!! should i try and replace it myself and are special tools needed?
Old Jan 3, 2001 | 01:44 PM
DannyP's Avatar
DannyP
I am sure there is a special tool to perform this task but I just use a wrench on the idler nut to release the tension on the belt. It really helps to have 3 hands tho. If you don't have a schematic under the hood showing the correct routing of the belt, be sure you draw one up yourself so there is no question as to how it came off.
DannyP
89 F-150 4x4 former EFI I-6 now carbed 351W, Edelbrock heads,cam,intake,carb.
MSD 6A, ZF, Sterling 10.25 with 3.55L's.
Old Jan 4, 2001 | 01:12 AM
whiteboyslo's Avatar
whiteboyslo
It is always a good idea to replace the belt as soon as you see anything like this. Believe me. I work in a parts store and you don't know how many times I get the torn remians of a belt thrown at me by a customer who said he/she saw the belt's condition but figured it could wait. As far as the tools and labor, serpentine's are fairly easy. There is a tool that is basically a long skinny socket wrench made to fit in the tight space, but it isn't necessary, just convenient. You can find it in almost any car parts store. Just be sure to run the belt correctly around the pulleys. One more thing, DON'T SKIMP ON THE BELTS! The El Cheapo brand is called that for a reason and broken down on the side of the road is not a good place to figure this out. From what I've seen, the Dayco brand is a great and reliable brand.
Old Jan 4, 2001 | 07:17 AM
Nate_64's Avatar
Nate_64
I'd like to offer a bit of advice if I could. either get two new belts or keep the old one behind the seat for a spare. It might be worn, but if you have a belt break unexpectedly, the old one will at least get you to a parts store.
Nate
1964 F-100 Custom Cab 292 V-8 3 spd
1964 F-100 292 V-8 3 spd
1990 F-150 5.8L
Check out http://clubs.yahoo.com/clubs/fordpickups61to66fseries
Old Jan 4, 2001 | 08:02 AM
AlM's Avatar
AlM
good advice!
i have a 96 bronco 5.0..have marked all the pulleys, etc. with a small white painted arrow .. just to help out, if the belt breaks
also, mark the rotation direction on the old belt with white chalk or masking tape and an arrow, if you keep it as a spare
.....just watch your fingers when replacing the belt, please!
Old Jan 4, 2001 | 10:17 AM
cgl's Avatar
cgl
I've had great peformance and luck with Goodyear's Gatorback belt. They're quiet and have a lifetime warranty. On my 90, I use a 5/8" socket and a breaker bar, takes about 60 seconds if you know the routing.
Ever notice the warnings on those sleeves? "Warning, Turn off engine before replacing belt"...
Old Jan 4, 2001 | 01:54 PM
nickc84's Avatar
nickc84
scott79
Aug 11, 2015 10:05 PM
Servando Abm Almaraz
1978 - 1996 Big Bronco
Feb 4, 2015 04:12 AM
quietman
Mar 24, 2014 12:43 AM
kennethpina
Dec 16, 2010 01:19 PM
blakeusa
13
Feb 10, 2009 09:15 PM
