V8 Engine Blocks
Old Jan 3, 2001 | 04:55 PM
cgl's Avatar
cgl
V8 Engine Blocks
Old Jan 3, 2001 | 06:46 PM
fordtrucktough's Avatar
fordtrucktough
V8 Engine Blocks
I was wondering the interchangability between 1986 and up 5.0 and 5.8 engine blocks. Will the 5.8 crank and heads fit in the 5.0 ?
Old Jan 3, 2001 | 07:05 PM
KevinT's Avatar
KevinT
V8 Engine Blocks
I believe the heads and cam are the only part that works...if you use the cam you need to flip the distributer around (reverse firing order of a 351)
1995 F-150 XL Reg Cab/Bed
http://members.sounddomain.com/blind
5-star rated F-150 (big stereo)
Old Jan 3, 2001 | 07:36 PM
Motorcraftsman's Avatar
Motorcraftsman
V8 Engine Blocks
exhaust manifolds,heads will work, i believe also the water pump, timming cover, valve covers, anything else simular in construction.
John Floyd
South Mills,NC
'86 F150 2wd 300 6
Crane Cam 260/272
stock manifolds, w/ staight pipe
Old Jan 4, 2001 | 02:48 PM
Pastmaster's Avatar
Pastmaster
V8 Engine Blocks
No I don't think a 351 crank will work in a 302 block. The journals are larger in a 351. That might only be true for certain years.
As far as the 351 heads on a 302, yes. You will have to do some drilling.
It might be less of a headache to use a 351 computer matched to the 351 cam. I'm sure it would work with speed density.
Pastmaster's 1993 XLT 5.0 E40d 3.55LS Normal Cab/Long bed Loaded from the factory with aid of...MSd 6a ign/s.p. wires, blaster coil, Hypertech Chip, K&N filtercharger, Cat-back dual exhuast w/o mufflers, 3.5", echo tips, Accel distributor cap, Dark Mocha over light mocha. 5% Dark tint, Alpine Cd player/remote, Pioneer speakers.
toydestroyer1(No Email Addresses In Posts!)
