89 Diesel Problems
Old Apr 7, 2005 | 09:24 AM
E&MCustoms's Avatar
E&MCustoms
Question 89 Diesel Problems
My Father in-law has past on to me a 1989 Extended Cab F250 4x4 Automatic XLT with a diesel engine. I has been parked for a while because he is unable to fix the problems. I can handle most of them but the engine since I do not have much prior knowledge of the diesel set up. I am looking for advice on the following issues:
1. The engine will not start without a little starting fluid. He has been using this method for the past 10 years. Outside of the glow plugs being replaced what other steps do I need to take to get this engine back to it's original starting ablities?
2. Anytime the engine is accelerated and then let off it promptly dies. Could this be problems with the injector pump or something else?
Old Apr 7, 2005 | 12:58 PM
d9d's Avatar
d9d
1 and 2 could -both- be an IP problem. But could also be air-leaks in the fuel system.
However, if a whiff of ether makes it start immediately, then the IP is fully fueled at crank-time, and that would point to a GP problem still. On the first start of the day, with air-temp around 40-50 say, your wait-to-start light should stay on for perhaps 10-12 seconds. Is it doing that?
If it's going off after only 5 seconds, then you still have at least one bad GP.
The GPC (controller) could be bad too; but that is not as common on these as it was on the 6.9's.
You can use the test-light method to check the GP's; but I find it unreliable. I've had more than one GP fail without going fully open. I've seen resistances like...2.5 ohms...and I just had one that was 4.6 ohms. That's low enough to light a test light, so you'd think it was good, when it isn't. I use an ohmmeter. A good GP should read in fractions of an ohm. Like... .15 ohm.
The stalling after acceleration is generally talked about in terms of a truck that's just been started. Are you saying that yours does it ALL the time, even after being driven for an hour?
Have you changed the fuel filters? That'd be the first step. Then run the lift-pump test....make sure you have enough flow and pressure at the test-port on the filter-housing. Also check for air-bubbles coming through in the fuel. Problems with the tank-pickups, the tank-selector valve, or any of the lines or fittings, can allow air to be sucked up with the fuel; and that gives the IP fits.
Richard
Old Apr 7, 2005 | 01:05 PM
E&MCustoms's Avatar
E&MCustoms
I have not changed GPs yet. Another thing is the truck has 300,000 miles on it, so when should I think about a rebuild and could this have something to do with the problems that I am having. The light goes off in about 5-6 seconds, however this truck has some electrical problems that I have to sort out. The stalling happens anytime from the time I start the truck to 30 min. later. It does it more on the front tank than the rear.
Orioles
May 17, 2010 05:21 PM
TinCocodrie
Jun 30, 2008 11:52 AM
turbogt
29
Jan 10, 2007 06:24 PM
DKRoff
Mar 3, 2004 05:27 PM
