Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
need source for long self-tapping screws
Old Apr 6, 2005 | 10:33 PM
mzimmers's Avatar
mzimmers
Hi, all -
I'm installing something on top of my bed rails. In drilling down into the rails, I don't seem to hit metal until I get about 2" deep (including the equipment I'm mounting), as the upper part of the rail appears to be some composite material.
Does anyone know of a source for #14, 2 1/2" self-tapping screws? I suppose there's probably a reason that they're not really common (didn't find them at Home Despot), but I have no options that I know of. I can't get to the underside, so a bolt/nut option is out.
Thanks...
Old Apr 6, 2005 | 11:43 PM
fordguy21's Avatar
fordguy21
I would try an independently owned hardware store, as they tend to have a bigger delection in nuts and bolts.
maybe use a molly bolt.
Old Apr 7, 2005 | 12:48 AM
rander101's Avatar
rander101
Screws such as you are looking for are often used to attach wooden floors to trailer frames. They are available at several trailer parts dealers. The link below is to TJ Trailers who have them in a couple of sizes. These are black oxide and require a 7/32nd hole but they are self threading.
http://www.tjtrailers.com/store/rivets-screws.html
McFeely's also sells a self-tapping screw for trailer floors that you might be able to use.
Try: http://www.mcfeelys.com
Old Apr 7, 2005 | 12:58 AM
mzimmers's Avatar
mzimmers
The ones that TJ sells is fine except I need either a pan head, or (ideally) a hex head. The fastener is going through a flat surface. Though I suppose I could countersink it, but that seems kind of odd to do to aluminum.
Their self-tapping hex screws would be perfect, if they came a little longer (they stop at 1 1/2").
I like the ideas...please keep them coming.
Old Apr 7, 2005 | 07:08 AM
rander101's Avatar
rander101
You might check this one out from Barnhill Bolt. Part number follows and a link to Barnhill Bolt catalog.
1 443-1214-212-018AA
#12-14 x 2 1/2 #3 TEK Screw, Steel,Zinc,Hex Washer Head, 100 Per Box, $11.49
http://www.barnhillbolt.com/
Old Apr 7, 2005 | 08:54 AM
mark a.'s Avatar
mark a.
Did you try MSC Industrial Supply ?
Old Apr 7, 2005 | 09:21 AM
Smokin_Superduty's Avatar
Smokin_Superduty
Try "Fastenal", they are a nationwide fastener company. I know they have exactly what you describe. http://www.fastenal.com/web/home.ex
Old Apr 8, 2005 | 05:13 AM
wiseguy's Avatar
wiseguy
You could also try www.nutty.com. They might have what you want.
Old Apr 8, 2005 | 10:49 AM
Bruker's Avatar
Bruker
If there's a company in your area that does commercial and industrial roofing (flat roofs), check with them. They use long self-tapping screws.
