Quad shock setup - Rougher ride?
Old Jan 10, 2001 | 11:01 AM
RGAZ's Avatar
RGAZ
My 88 F-150 has the Quad shock setup and I want to know why this was offered for my truck? Is it supposed to give a better ride? Or a more agressive shock combination? What it does do is make you feel every bump in the road since it seems too stiff for day to day driving to me. What can I do to ease up the stiff front end? I already replaced the shocks and it handles better but the ride is rough, even for a truck.
Give me some ideas here.
Randy
88 F-150 4x4 302 M5OD
Old Jan 10, 2001 | 12:02 PM
PAUL_2's Avatar
PAUL_2
I have the 4 shock setup & its stiff . I think the quad setup is designed to handle the off road possibilities . I have Ranchos & I dont notice any diff between them & the Ford shocks . What I did a few months ago that improved the ride esp over bumps was replace the the two front body mount bushings , mine were rotted away to nothing . That made a lot of difference in ride quality . They werent too hard to replace , although I did have to use a large pair of Vice Grips to hold the metal spacer , the bushing bolt threads thru the whole bushing & when you try to remove the bolt the whole thing turns & wont loosen until you hold the spacer .
Old Jan 10, 2001 | 12:09 PM
RGAZ's Avatar
RGAZ
Where are these mounts located? Did you use Ford parts or aftermarket? Rubber or Urathane?
Thanks Paul,
Randy
Old Jan 10, 2001 | 01:19 PM
PAUL_2's Avatar
PAUL_2
[font size="1" color="#FF0000"]LAST EDITED ON 10-Jan-01 AT 02:23 PM (EST)[/font][p] I got the Ford ones , Its a 2 piece bushing & I got new bolts because mine were rusted pretty bad . Part No E2AZ 5400155 A , EOTZ 1000396 A & two M12 bolts & nuts , It all came to about $55. They are the two very front body / cab mount bushings . The other cab bushings were fine , I guess because of where the front ones are they catch a lot of water & deterorate faster .
Old Jan 10, 2001 | 05:59 PM
dewfpo1's Avatar
dewfpo1
rally68
Mar 26, 2016 12:35 AM
bb65f1004x4
May 11, 2015 02:38 PM
MDSLIGHT
May 26, 2014 08:33 PM
Rifboy
2009 - 2014 F150
May 9, 2014 07:48 PM
smittys800
Oct 24, 2013 06:56 PM
