Ford Econoline E150 towing
Old Jan 11, 2001 | 08:12 PM
Pastmaster's Avatar
Pastmaster
Old Jan 12, 2001 | 10:09 PM
pr
I tow a 28 ft travel trailer with a '92 Ford econoline E150, 5.0L V-8, with towing package. The van pulls the trailer fine, but I have had the van shutdown 3 times in the past 2 years when the air temperature reading is 95 degrees plus. The temperature gage still reads in the normal range, a little above where it normally reads without pulling th trailer, and well below the red zone. Has anyone heard of similar problems, any solutions. Possible vapor lock? I have taken the van to Ford for diagnostics when the problem was happening, but after cooling down, they can find no problem. I read where motorhomes on the Ford chassis had vapor lock problems, and needed an upgrade to a turbine type pump. I showed this article to the Ford service shop and they said there is no upgrade for the fuel pump on the Econoline van. Any info on this?
Thanks,
PR
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
