Sponsored by: Kumho
Front End "SLOP"
Old Apr 5, 2005 | 03:51 PM
bcsnave's Avatar
bcsnave
Front End "SLOP"
I have a 1996 F -150 and the steering seems a little loose. I have new ball joints and shocks on the truck. It is a 2wd, with a 4.9L six cylinder. It has about 81,000 miles on it. Any suggestions on how to get this tighter?
Bill
Old Apr 5, 2005 | 04:05 PM
andym's Avatar
andym
It could be tie rod ends, axle pivot bushings, radius arm bushings, or a combination of the above. See my other post a few minutes ago.
It could *also* be the steering box or something in the linkage (rag joint, etc). The steering box can be tightened with the screw on top, but is obviously only going to work if none of the other components are at fault.
Old Apr 6, 2005 | 01:35 PM
73Custom's Avatar
73Custom
Have someone turn the wheel back and forth as you inspect each of the steering linkages. Start with where the steering column attaches to the gearbox and work your way through all the tierod ends. If there is any play or looseness, they need replaced.
Marty
Mtnhermit
Apr 30, 2016 12:57 AM
thegorilla
15
May 22, 2014 08:38 AM
Dutch123
1978 - 1996 Big Bronco
Jul 9, 2010 04:48 PM
Eric_F250
24
Mar 24, 2009 08:48 PM
