Timing
Old Apr 4, 2005 | 03:47 PM
agoldwinger's Avatar
agoldwinger
Question Timing
Have had overheating problems on my stock 76 460 F250, found to be total timing, have reduced from 52 to about 40 . Does anyone know what it should be and a easy way to reduce it more (ran out of adj. on the vac adv.)
<!-- / message -->
Old Apr 5, 2005 | 10:30 AM
smoke n tires's Avatar
smoke n tires
i have the same problem on mine. you might need to reduce the base timing more or have the distrubutor recurved. does yours overheat at higher rpms? i think my timing is around 46 @2500 rpms. its suppose to be around 36 @2500 rpms.
Old Apr 5, 2005 | 12:27 PM
agoldwinger
You might adj the vac. adv (allen in vac hole) I lowered mine about 12........
Old Apr 5, 2005 | 01:56 PM
smoke n tires
do you turn it in to lessen the vac or out? mine gets hot on the interstate, at about 3000-3500 rpms. how about yours?
Old Apr 5, 2005 | 10:33 PM
agoldwinger
I don't remember, I think out. move it a little and recheck........
