D3 heads
Old Apr 4, 2005 | 04:50 PM
jimlj's Avatar
jimlj
D3 heads
What does it take to make D3VE heads to preform well? I recently bought a rebuilt short block that I was planing to use the C9VE heads off of my existing 460. I would need to have a complete rebuild on them. I since have found several sets of rebuilt D3VE heads on ebay, that are far less than rebuilding my own.
Am I better off rebuilding my C9 heads?
I want to run this truck on pump gas with no problem, and am afraid the C9 heads might give me too high CR. The truck is a '79 F250 4X4 extended cab used for towing and daily driving.
Old Apr 5, 2005 | 10:26 AM
smoke n tires's Avatar
smoke n tires
the d3s flow well but they just have low compression. if you want drivability and no pinging i would just use the d3s with a good valve job and cleaning. save the c9s for a performance build.
Old Apr 5, 2005 | 11:24 PM
kermmydog's Avatar
kermmydog
From listening to the people here porting the exhaust ports is a must and camming with a cam that gets the exhaust out is also important. Remember low compression doesn't mean it will run better. I beleive getting the compression up to 9.5 to 1 would be better for fuel mileage, smog, and performance. I was told my 86 F250 460 stock maybe lucky to have 7.9 to 1 compression. It will run on 80 octane gas the problem is it still is $2.50/gal.
