Timing
Old Apr 4, 2005 | 10:45 AM
agoldwinger's Avatar
agoldwinger
Question Timing
Have had overheating problems on my stock 76 460 F250, found to be total timing, have reduced from 52 to about 40 . Does anyone know what it should be and a easy way to reduce it more (ran out of adj. on the vac adv.)
Old Apr 4, 2005 | 12:47 PM
ford390gashog's Avatar
ford390gashog
put this in the engine forum, but it should not be more than 36 total advance
Old Apr 4, 2005 | 08:07 PM
LxMan1's Avatar
LxMan1
36-38@3000 rpm is about right. When I bought a new distributor for my 460, it had the large vacuum advance diaphram unit on it and I was getting about 60 deg. of total advance from 12 deg initial. I changed the vac. adv. unit to a smaller one off of an old 302 distributor that I had laying around and it dropped to 38 total with 12 initial.
Old Apr 4, 2005 | 08:39 PM
agoldwinger
Ok thanks, I was hoping not to replace the vac. adv. The dist. and vac adv are 6 mo old (rebuilt)
Old Apr 4, 2005 | 09:28 PM
Bear 45/70's Avatar
Bear 45/70
What is the intitial timing set at? Also the engine should sound like a case of old coke bottles rattling (pinging) down the road with this much advance. How are you checking this total advance? With the vacuum line from the carb disconnected from the dist. and plugged? Something is seriously wrong to be able to get that much advance.
scatgo
18
Mar 14, 2008 03:49 PM
FordTrucksKickGM
Feb 17, 2008 11:49 PM
just-n-time
Paint & Bodywork
Nov 30, 2007 08:23 PM
MercM47
Jul 1, 2003 05:00 PM
myst
Nov 26, 2002 02:57 PM
