ZF5 Fluid
Old Apr 3, 2005 | 08:28 PM
68torino's Avatar
68torino
ZF5 Fluid
Stick with regular Mercon/Dexron III or go synthetic? If you've run syn. what type and how'd the trans do? I'm going to be swapping out both the trans. and t-case fluids. I would like to sweeten up the shifting. Pulling into second starting out or coming back down I have to ease'er in, All other gears are fine.
Also can I grease the throwout bearing? I used to run construction trucks and got used to lubin the throwout bearing.
1989 F250 XLT Lariat 4X4.
Thanks
Duane
Old Apr 4, 2005 | 12:00 PM
rclarke's Avatar
rclarke
Synthetic mercon III is fine and is the required oil for diesel applications.
Old Apr 4, 2005 | 01:43 PM
frederic's Avatar
frederic
All S5-42 Transmissions (exc. D.i.t.) Use Dexron Ii / Mercon Xt-2 Qdx Or Ddx.
Old Apr 6, 2005 | 12:57 PM
68torino's Avatar
68torino
Thanks guys much appreciated!
Bagbyknoter
May 28, 2011 07:32 PM
glovemeister
16
Jan 29, 2011 03:41 AM
jmadsen
Aug 8, 2008 08:21 AM
Levergun
May 10, 2004 04:41 PM
