1978 - 1996 Big Bronco
AC pressure switch problems?
Old Apr 3, 2005 | 10:43 AM
muckypaws's Avatar
muckypaws
Hi,
After a recent warm day I turned on my AC but didn't get cold as expected.
I have checked and found the following so far.
Fuse for compressor ok.
Compressor not turning on.
Short out contacts on pressure switch and compressor starts
with compressor running as above air still at ambient with fans on.
Check continuity across pressure switch - open circuit.
Switch continuity does not change after running compressor for 10 mins or so.
Depress plunger on a/c gas valves under dust caps - very little pressure so suspect no Gas.
Will get gas recharged on Monday but....pressure switch...
I would expect it to be closed circuit when pressure low or compressor would never run. Do they go bad? Are they adjusable? I note a screw between the contacts recessed within the switch socket.
Thoughts please.
Simon
Old Apr 3, 2005 | 02:21 PM
94Bronco58's Avatar
94Bronco58
Yeah they do go bad, mine actually just went out and I got it replaced, I had a shop test it to see what was wrong with the AC system and they bridged the connection at the low pressure switch and it fired up!
Old Apr 3, 2005 | 04:47 PM
muckypaws's Avatar
muckypaws
is it possible to change the switch without loosing the gas? I assume the sensor is open to the gas pipe so removing it will let whats left escape.
Old Apr 4, 2005 | 01:24 PM
fcarruth's Avatar
fcarruth
If you don't have a good freon charge, the compressor will not come on either. That happened to me a couple Summers ago.
Good luck,
Old Apr 4, 2005 | 01:28 PM
muckypaws's Avatar
muckypaws
I've arranged for a AC guy to come have a look with it and spoken to my mates in GA who are in the AC business and they have confirmed to check the gas before changing the switch. Also apparently the orifice tube is prone to getting gummed up too - a $6 part. I but they cost a hell of a lot more over here!
Will let you know the outcome.
Old Apr 4, 2005 | 07:19 PM
BOJOFASO's Avatar
BOJOFASO
i do believe the switch can be changed without losing the freon charge.and if you are low on freon the compressor will not run.
Netroamer
Oct 16, 2021 12:26 PM
scott79
Jun 13, 2021 02:05 PM
aaron8669
Large Truck
May 2, 2018 08:06 AM
5.0 Heaven
Jun 24, 2013 06:49 AM
VA250SD
May 12, 2012 11:58 AM
