I have heard that a 4.9 liter Inline 6 in a cool running engine. I cant seem to get any heat out of my engine. The guage is always on the "c". So I was wondering what I can do to make it run a little warmer? or if there is anything TO DO? I have a 1989 Ford F-150 4.9 2WD XLT Lariet All help is appriciated!
Check to be sure it has a thermostat in it and check to be sure that it is the correct temperature rating. also if you have a clutch fan make sure that the fan turns freely when the engine is off and cool. You also might change the sending unit, it may not be reading correctly. Hope this helps.
If the heater barely works and warms up just enuf to keep you alive on a 12 degree F morning then it is working OK My truck pulled that stunt when it was around 40,000 miles. I went all winter freezing my butt off. Changed the thermostat flushed the cooling system and refilled with new fluid and all was OK.
Actually, the 300 has a higher tendency to overheat that the V8's do. The coolant has to flow around 6 cylinders in a 300, and only around 4 in a V8. So they don't keep cool as easily.
If the gauge is always on C, the sender is probably bad. Even with no thermostat, it should move a little. Make sure you replace the thermostat with a 195 degree one.
yes the heater does work but it is like 924X2150 was saying in his post it barley keeps me warm. I have checked the anti-freeze level and it is always full. I will check to see if the thermostat is in there and/or put a 195 degree one in. I was also thinking about flushing the cooling system or do you think that is nessesary. Where is the sending unit located at?
Thanks for all the help I have already got and please send more!
The cooling system should be flushed every 30,000 miles. If you just got it, chances are the previous owner never had it done, and you should think about doing it.
The sending unit for the gauge is on the passenger side on the rear of the block, just under the exhaust manifold. Easy to get to, right? I usually drop the starter, but I've heard of other people getting to it from the side.
If there's not enought heat it's probably the tstat. Even if there's one in there that doesn't mean it's working. They'll fail and stay open and you never get enough heat. Toss that and put in a new one. They're only $5. My truck keeps me toasty warm no matter what the temp is outside. I flushed mine this past summer. The overflow tank was so rust coated that you couldn't see the green of the coolant. It was dark. There was an inch of rust powder on the bottom. I took out the overflow tank and blasted it clean with the hose. Then I flushed the system. It took forever to get it to where rust wouldn't come out. Then guess what. Water pump starts leaking. I guess all that rust buildup was keeping the water pump sealed. Replaced that next and now all is well. But I ain't kidding. My coolant was the color of rust. It wasn't green. This was at 140K mi. I bet the coolant had never been changed. It was probably original.
Speaking of cracking things....I had a leak from the upper hose at the radiator inlet. Since it was a new hose I kept tightening the clamp thinking the assy. will settle and seal sooner or later. After a week of leaking I finally took the hose off the upper port of the radiator and found the plastic inlet had cracked close to the side tank assy. I am thinking I leaned on it one too many times or overtorqued that clamp.
Moral of the story;be careful the sidetanks are plastic!
I wouldn't touch the coolant sensor, my truck was on "C" the first winter after I bought it, (November 95) I changed the thermostat later and it was OK after that. If you are cold in the cab, and the guage reads zero, then all clues point to an overcooled engine due to a stuck-opem tstat.
With mine,when it gets really cold the truck will not warm up enough to pump out heat. I put a piece of cardboard between the radiator and the AC condenser and the problem was immediately solved. I was reminded of this midwinter fix yesterday when it got really warm for the first time, and the temp rose 3/4 of the way across. I pulled over and took out the cardboard........all is well!
