Inline 6 questions
Old Apr 5, 2005 | 09:50 AM
ARMORER's Avatar
ARMORER
Originally Posted by rhetor
It technically shouldn't be doing that.
If the cooling system is working correctly there should only be flow through a pinhole.
What do you mean by that? You mean if the thermostat is closed there is only a pinhole sized opening it is flowing through? So, in other words my thermostat is bad? Please clarify if you have the time. Thanks!
Old Apr 5, 2005 | 10:09 AM
corpsedub's Avatar
corpsedub
correct. there should be almost no flow through the upper hose when the tstat is closed. the water outlet should only be flowing coolant to the heater hose which is a seperate casting on the outlet.
Old Apr 5, 2005 | 01:26 PM
ARMORER's Avatar
ARMORER
Thanks, I now see that I will be installing a T-stat very soon................
Old Apr 7, 2005 | 01:21 PM
harmdogg1978's Avatar
harmdogg1978
Thanks guys for all the help
f-150_38.5s
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
13
Nov 19, 2021 04:07 PM
Kregj
27
Aug 3, 2014 02:15 AM
Wicked Endings
North Carolina Chapter
Jan 23, 2011 12:06 PM
coldnorthpole
Oct 5, 2006 05:28 PM
