Engine Whistle
Old Apr 1, 2005 | 12:53 PM
dnirenberg's Avatar
dnirenberg
Engine Whistle
My 2004 V6 Explorer whistles at 2100-2300 RPM. Changed out IAC, and that didn't work. Any other suggestions?
Old Apr 1, 2005 | 04:03 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
Please read this.. https://www.ford-trucks.com/forums/s...d.php?t=300691
We are happy you have chosen the best source for Fords!
Enjoy FTE and
JOIN CLUB FTE -SUPPORT THE FORUMS!
See you on the boards. ….
Old Apr 1, 2005 | 04:14 PM
Golfmore's Avatar
Golfmore
Sounds like a vac leak somewhere. I'd look at the manifold and ???? Even a hose.
Old Apr 1, 2005 | 09:03 PM
CTford's Avatar
CTford
My 2003 seems to do the same thing... although mine sounds more like a high pitched beep (or you could describe it as a whistle) at the same RPM's. same 4.0L SOHC V6. What does your's sound like- I think we have the same problem. It does not seem to affect the running of the car.
Old Apr 2, 2005 | 07:43 PM
ShouldaBoughtAToyota's Avatar
My 2003 does the same thing at the same RPMs, but only when it is ice cold. The colder it is the worse the whistle. It fades as the engine warms up, and then it also reappears around 50-60 mph (same RPMs, different gear). Now that the weather broke I'm positive that the dealer won't be able to replicate it therefore the problem cannot possibly exist. (This has been Ford's way of thinking with every other complaint that I've had.)
I'm sorry but I can't help but digress from the issue. If you find out any more info please post it. I willl post whatever I come across.
Old Apr 8, 2005 | 11:28 AM
jcmac's Avatar
jcmac
Wink
I have been experiencing the same thing too. Now that the weather is warmer it seems to have gone away. However, I have noticed the idler pully for the serpentine belt (located near top front of motor) seems to wobble during motor operation and I will try to have it replaced. It could be the culprit... In my 97 EB V8 a similar idler pulley produced some very strange noises as well. Once the item was finally replaced, after the entire exhaust and water pump, the noise never returned. I have not yet gone for service for it but will likely do so in the next few days.
Old Apr 8, 2005 | 01:33 PM
TruckLarry's Avatar
TruckLarry
Did someone accidently install a TurboCharger ?
I only bring up this silliness because I know of a case where a customer complained of whistling under accelleration, and it was the Turbo
-Larry
Old Apr 8, 2005 | 01:34 PM
TruckLarry's Avatar
TruckLarry
Oddly, I think the belt tensioner on my 03 Ranger I traded in may have been going bad too.
Is there a pattern here?
-Larry
Old Apr 13, 2005 | 08:34 PM
jcmac's Avatar
jcmac
I just had the part replaced, the idler pulley. The noise has not yet re-appeared. However the new part is rock steady where the old part wobbled about 1/4 inch in a lazy manner. If the noise returns I will report. BTW the part was under warranty so it was a good fix!
John
Old Apr 19, 2005 | 09:00 AM
dnirenberg's Avatar
dnirenberg
thanks, please let me know if the whistle returns.
Old Apr 19, 2005 | 09:47 AM
Shadowe's Avatar
Shadowe
It is possible that it could be this.
First, watch this . . .
http://www.pr0n.com/images/misc/carwhistle.wmv (Work Safe)
Then, click here . . .
http://lisupras.com/wooo.html
Check your Exhaust to make sure that Bubb Rubb hasn't modified it while you weren't looking.
David Vawter
Want a Free IPOD!
http://www.freeiPods.com/?r=9181869
Old Nov 28, 2005 | 10:55 AM
rjd75's Avatar
rjd75
Any success with resolving this issue? It sound exactly like my problem. Really annoying on the highway in cold weather!!
-R.
Old Nov 28, 2005 | 04:58 PM
jcmac's Avatar
jcmac
The noise has completely dissapeared. In fact I had forgotten about it until you mentioned it.
Old Nov 28, 2005 | 11:28 PM
Jharger's Avatar
Jharger
On my 173K mile 93 4.0 last week I fired it off and heard a terrible scretching noise form under the hood. Immediately thought a bad bearing on one of the serpentine belt driven accessories. Came from Alternator area. Picked up new alternator and belt. Removed old belt and spun the idler and tensoiner pullies - both sounded bad. Old alternator pulley was wobbling too much for my taste. Replaced the alternator and put it all back together and drove it to Napa. Got 2 new sealed bearings #6203 ($10 each) and back home to tear it apart again. Popped out the old bearings with a big socket and a hammer - new bearings in the same way. Now it pures like a kitten again.
But this was never a whistle. I get a cool sounding whistle at just the right flow/RPM ratio through my cold air intake. Sounds like a Deisel truck. But hey - if original posted recently added one of these cold air intakes - could be the culprit.
Old Nov 29, 2005 | 08:25 AM
rjd75's Avatar
rjd75
jcmac,
Do you have the papers for the warranty work? How much labour and parts were involved in this fix.. I am going to have to pay to get this done now so I am willing if it is not ridiculously expensive.. Where is this pulley located? Is it something someone mechanically inclined could do themselves? It would be a dream come true to finally get rid of that after 3 winters of whistling!
-R.
