Engine Whistle
Old Nov 29, 2005 | 10:05 AM
Jharger's Avatar
Jharger
On my 93:
Got 2 new sealed bearings #6203 ($10 each) and back home to tear it apart again. Popped out the old bearings with a big socket and a hammer - new bearings in the same way. Now it pures like a kitten again.
It's fairly easy to do. I had my radiator fan and shroud out at the time as I was replacing the fan so I had a lot more room. But you can still get the pulleys off with the fan on. There's a tension pulley you rotate with a socket wrench - mine was 16 mm. Belt falls off. For the tensioner, mine was left hand threads so watch out for that. The idler pulley was right hand threads. The pulleys are a simple pressed steel cup so littereally, use a big socket and a hammer to bang the bearings out and back in again.
First thing you need to do is pull a pulley off and read the bearing number on it. I see no reason why Ford may have changed this on your year but they could have. These ae not Ford numbers but industry standard so any good auto parts store will have them.
Old Nov 29, 2005 | 05:04 PM
jcmac's Avatar
jcmac
rjd75,
There was only one part the idler pulley, it is at the very top of the motor (v6-4.0). At most there would be 1 hour labour. I no longer have the truck so I can't take a picture. It is NOT the tensioner pulley which is located lower to the left as I recall.
John
Old Nov 29, 2005 | 11:01 PM
Jharger's Avatar
Jharger
Maybe changed. The top one on my 93 is the tension pulley with a fixed idler just below the alternator. With the alternator, all were suspect so they all got changed.
Old Jan 3, 2006 | 10:19 AM
rjd75's Avatar
rjd75
had the pulley chaned and noise is still there.. What is next to try the IAC? what are they worth, easy to change?
Old Jan 3, 2006 | 10:25 AM
Jharger's Avatar
Jharger
IAC is easy. 2 bolts I think. $45 to $75 depending on the source. some claim these can whistle.
waystro
47
Mar 26, 2016 01:47 AM
CobraXP
Jan 14, 2003 08:37 PM
Diesel Steve
Aug 30, 2002 08:02 AM
orange peel
Jan 20, 2002 03:42 PM
PAUL_2
Oct 19, 2000 04:20 PM
