General Automotive Discussion
Taurus (Ford Car) Forum?
Old Apr 1, 2005 | 12:05 PM
hoganlo's Avatar
hoganlo
Can someone point me to a good forum for my 92 Taurus questions? Thanks!
Old Apr 1, 2005 | 12:18 PM
77fordguy's Avatar
77fordguy
sho or regular taurus?
what questions do you have, us gearheard may be able to help?
Old Apr 1, 2005 | 02:13 PM
hoganlo's Avatar
hoganlo
It's a regular Taurus 3.0 6cyl. I tried to find out what's going on (check engine light has been activated) by "buying" the OBD-1 scanner from O'Reilly (they let you buyu it for $215 and then credit you back upon return). But, I nor they could find the interface on the car for it!
So,
1) Does anyone know where you plug in the OBD-1 scanner on the 92 Taurus? Looked all under the hood and dash with no luck!
I bought used (123k miles) and have changed the Fuel Filter, plugs, wires, cap rotor. Radiator has leak and I have bought a new one to replace.
One problem - The carwill start and if I let it run for a while (5 minutes) and then reverse and then drive it WILL run. If I just start it up, reverse and then drive...it stalls out. So, it definetly has a power problem...EXAMPLE - If you start it cold and then twist the steering wheel back and forth real quick the power steering is enough to get it to stall cold (strange huh!!).
I think it's the idler air flow valve, but wouyld like to be certain.
2) Any idea of other parts that may be causing the power /idling problem?
3) Today (just started) it is now idling high (too high because when I let off the gas it maintains speed). The tranny now shifts better (another issue) but when I come to a complete stop it revs up and then lurches as it downshifts (very hard). Any thoughts!
4) If I take it in for tranny fluid/filter change...do you think it will do more harm than good?
Thanks!
Old Apr 1, 2005 | 02:27 PM
Racerguy's Avatar
Racerguy
The OBD test connector is on the passenger's side of the firewall, near the A/C lines.
It sounds like your IAC (Idle Air Control) could be bad.
Old Apr 1, 2005 | 03:27 PM
hoganlo's Avatar
hoganlo
That was the only place I saw an open plug...but I didn't think the interface that came with the scanner would fit...I'll try again. Thanks!
Old Apr 17, 2005 | 12:47 PM
hoganlo's Avatar
hoganlo
Hello. I've replaced the Idler Air flow valve and no longer have the 'Engine Light' coming on. However, (even before I changed the Idler Air Flow valve) the idle seemed to pick up substantially. It now runs too high. I adjusted the cable and yet it still runs too high. It no longer stalls after starting it BUT it now shifts very hard when com9ing to a stop. Also, when putting back into park. It's as though I had one foot holding the gas down while stopping or putting into park. <b>Does anyone know excatly what the "Throttle position sensor" does? I was thinking of replacing that since it is only about $25 but wasn't sure what exactly it will benefit me!</b>
Old Apr 18, 2005 | 11:02 AM
IAMCDN's Avatar
IAMCDN
www.tauruscarclub.com is a forum I go to quite a bit. Check it out.
Old May 1, 2005 | 04:59 PM
hoganlo's Avatar
hoganlo
Does anyone know if you can use R-134 for a R-12 system? If not, is there a substitute for R-12?
Old May 1, 2005 | 05:13 PM
fordbeast_80's Avatar
fordbeast_80
You would need to change fittings, usually in the kit you would buy. You should change the receiver/dryer as these are also a filter and should be changed. About all I can think of. Also I would do a search online as I have heard of a product called Freeze12 that takes the place of R-12. You must have the old R-12 recycled and a vacuum pulled on your system before adding R-134a.
Old May 1, 2005 | 05:37 PM
Rockledge's Avatar
Rockledge
If you want to use R-134, you have to make a few changes to your current system. If you do the changeover, then do it once and do it right. Pick up the kit from Ford (yea it costs a little more) and then follow the directions in the kit. You also might obtain a tip or two HERE.
Old May 2, 2005 | 03:57 PM
hoganlo's Avatar
hoganlo
Thanks y'all! I'll probably look into the Freeze12 first...since I'd rather not deal with changing things out for this vehicle.
