highboy tranny problems
Old Apr 1, 2005 | 09:53 AM
haten'chevs's Avatar
haten'chevs
I've got a 400/c-6 in my highboy, the problem I have is the first time you put it in drive for the day it just sits there, then after about 20 seconds (rough guess) it takes ahold and goes. It will work fine all day no matter if you shut it off or whatever, but then the next morning same thing. If you put it in reverse right away its fine, but then when you shift to drive same thing. Its been like this since I bought it in 2000. This winter I took the motor out to freshen it up, the front tranny seal looked like crap so I replaced it figuring that was the problem (figured it was suckin air and not priming pump right away), I also installed a B&M shift kit with new filter and fluid, and it still does it. Thought it was the vac line, checked that and it looks good. Tranny is good and strong and pulls my 5th wheel with 1700/ gallons of water and chemicals fine. Any ideas would sure be appreciated.
Rob
Old Apr 1, 2005 | 10:13 AM
billyj005's Avatar
billyj005
mine did that too. theres some oring like seals on the main shaft that leak out there oil over night. i dont think it hurts any thing but i know its real anoying.
Old Apr 1, 2005 | 08:26 PM
bottlefedchevy's Avatar
bottlefedchevy
not sure if this helps...cuz i'm a chevy guy, but when chevys do it most of the time it is the vacuum modulator that the vac line goes too...i don't know if they are on fords since my truck is a manual but its worth a try
RJ sheedy
Mar 7, 2017 08:41 PM
grumpyinme.
Nov 8, 2016 07:46 AM
fordf350man
20
Jan 21, 2016 08:06 PM
nick_ct_203
Dec 31, 2015 03:45 PM
johnsonacres
Oct 4, 2003 05:32 PM
